I'm working on hanging an Ikea Lisabo shelf. Earlier, I put one on a wall without much trouble using snap toggles, which are great. However, this second shelf, on a different wall, is giving me trouble.
The wall seems to be drywall, or possibly plaster, over plywood, followed by a small air gap, and then brick. The picture below shows a hole I drilled, illuminated by a flashlight. Unfortunately, the air gap between the plywood and then brick is insufficient to snap snap toggles into place; they require 1⅞" inch clearance in which to rotate flat after being inserted into the hole. I bought 3/16" standard spring-loaded toggle bolts, hoping they would require less clearance. I was able to get one of the two required toggles to open in the air gap, but the other won't — it appears that the distance between the plywood and the brick wall isn't uniform, and there's not enough clearance on the left hole.
Now I'm wondering what to do next. Two ideas I've considered:
  1. Put some type of mounts into the brick behind the hollow wall. I've never mounted anything to brick or cement, so I'm not really sure whether this would work. I'm also worried that the approximately 2" of distance between the brick wall and the shelf could severely reduce the shelf's capacity, because the screw or bolt will be unsupported for that length.
  2. Drive large-ish wood screws through the drywall/plaster and into the wood behind, making sure they're short enough that they don't strike the bricks. My two concerns here are whether two wood screws would be strong enough, and also whether the wood backing is thick enough to provide adequate support. I don't think it's simply plaster laths, as it seems too thick for that, but I'm not certain.
How should I proceed in mounting the shelves?
layers of wall
Regarding duplicates
I made an attempt to find duplicate questions before asking this one, but none seem quite to match my situation. Here are a few close ones, though:
ravron
  • 151
  • How about cutting a bit off the ends of the spring toggles? – JACK Jan 21 '20 at 01:57
  • That's not a bad idea. I'll give that a shot with a dremel. It's hard for me to tell just how much extra clearance I need on that left hole, but I think it might be a lot, meaning I'd sacrifice nontrivial strength to get the spring toggle to open. – ravron Jan 21 '20 at 01:59
  • What is the wood? Is it old-school lathe behind the plaster? Personally I'd find the vertical studs in the wall and use them. At the bare minimum I'd put two screws on one bracket into the stud. Your access hole in the photo should help to measure to the studs using a wire or similar. – Criggie Jan 21 '20 at 02:24
  • Good thought, but the section of wall is awkwardly narrow, such that there’s only a few inches of horizontal freedom. Because shelves have just two mount points, I can’t position them so that either mount point is over a stud. – ravron Jan 21 '20 at 02:30
I ended up buying a half-inch masonry bit and drilling into the brick behind the holes far enough so that I had sufficient clearance to deploy the snap toggles.
ravron
  • 151
