The extended sill would have a depth of about 2 inches.
If I were to extend the window sill using the below approach, would that be strong and stable enough? I may plan to add an additional interior window on that sill.
What can I do about the gap so that it is not noticeable? I am not a woodworking candidate, so I would want to not have to do any wood cutting if that's possible.
Also, if the extended sill is not at the height as the existing window sill, can I add a spackling or wood plastic paste to match their heights? Would that cause any issues when I add additional window on that?
Can I use this updated design instead ? The image also has the 4 positions in which I will screw. Also, I have extended the support to touch the wall.
Sandy
    **I think removing the old sill and making a new one the size you need is the best approach**. If you do it the way you want you could use a router to create the reverse of the bull nose curve in your new piece so the gap to fill would be much less. *It is difficult to do wood working with out cutting wood*. Perhaps hiring someone is the best approach. – Alaska Man Feb 02 '20 at 20:19
  • It should be wrapped with aluminum trim coil, otherwise if you neglect to paint and keep good caulk in there it will rot out within 10y. - Instead of a support you could bore holes half way into the face of the new sill for screws (to be long enough). Also, preserve the pitch of the old sill. – Mazura Feb 02 '20 at 22:31
    Can you provide pictures of the existing? (Both far enough to encompass the entire window and close to one of the corners.) It's a terrible hack, imho, but your best bet might be put one single ~4" wood (not mdf!) cap on top of the existing. (No seams, relatively little cutting.) – Aloysius Defenestrate Feb 02 '20 at 23:33
  • @Mazura Aluminium trim coil around the entire sill, but not the rest of the frame? It's the interior window I am asking about. Is that too much? I would definitely paint, if I fill in with something.Are you suggesting that I should horizontally screw it from the extended sill all the way up to my old sill? – Sandy Feb 02 '20 at 23:36
    PS, as drawn, the new sill (red) is structurally extremely weak. Any pressure on the front will split the old one where you've screwed into it. – Aloysius Defenestrate Feb 02 '20 at 23:36
    Oh, **it's an interior window sill** (which don't have a pitch) nevermind. - use horizontal screws; no support block, because of what Aloy said. Use exterior grade (thicker), *not drywall*, screws. – Mazura Feb 02 '20 at 23:46
  • I have added the photos. – Sandy Feb 02 '20 at 23:50
  • Also, updated the design from the comments suggested. – Sandy Feb 03 '20 at 00:04
  • FYI - That is a stool cap. Not a sill. – Brian H Sep 28 '20 at 22:10
First, thank you for adding the pictures. It helps a lot.
My best suggestion would be to remove the existing ~1.5" sill. (Properly speaking, it's a stool, with an apron below.) Put a new 4" or so one on. You'd probably have to remove the apron temporarily, as the thickness of the new stool might or might not be exactly the same as the old. Use long horizontal screws (1 per foot), well countersunk, that go at least 2" into the window frame. The worst case is that they glued the stool to the window jamb and you'll have a bit of splintery mess to clean up. It'll disappear with a bit of filler.
Otherwise, you have room to add a whole new ~6" or so on top of everything existing. Screw down at the window side into the window jamb. Caulk the joint between the new stool and the window trim so that condensation doesn't collect below. The downside to this plan is that the aesthetics of a stacked stool strike me as a bit odd, and you'd have to be a little bit fancy with cutting the new stool to fit. (There's lots of information about making templates to match irregular shapes out there.)
As I mentioned in the comments, use real wood for this, primed on all sides. Never MDF.
edit: As requested from the OP in the comments, a critique of the second plan.
Structurally, it's better to have long screws horizontally into the wall and the add-on stool. That overcomes my initial concern that you were just going to break the original stool. Countersink and counterbore the new pieces so they don't bind when being screwed.
The crack can be filled with a two part wood filler (like Bondo), which will function fairly well. Paradoxically, you'd want a thin gap between the old and the new stools, as the filler will be able to flow below the roundover and thus lock itself in. You can force this crack by putting a metal washer on each horizontal screw. The trick with Bondo is to catch it as it hardens and cut it flush. (The best time is when it's like a firm jello. Poke the leftover filler to decide when you've hit that point.) Use a long sharp, slightly flexible blade (like an Olfa knife) to slice. If you cut too deep, you can add another layer. If you waited too long, you can sand, but that's work.
Prime and paint. You're done.
FWIW, removing the old stool wouldn't involve breaking the vertical casing. As I said, the biggest risk is that it was glued, which would mean a bit of chisel work to make a clean edge. It's absolutely true that a new stool would require a bit of fancy cutting, so I understand if you're reluctant.
  • 20,214
  • 54
  • I understand the approach I am following may not be the best one, but can you please critique on the second design too. I really want to avoid removing something that's already there. I am not sure what other parts need to be cut before I can remove the stool. (just the apron, or would I have to damage the vertical casing too). I understand your answer is possibly the easiest and most logical for someone who is at least an amateur in woodworking. – Sandy Feb 03 '20 at 14:33
