12
I'm getting ready to install metal roofing on my building project. Wee! But I'm not sure how I should cut it.
The roof is a simple gable, 20ft long, with 8ft rafters. The roofing I'm using is 3ft wide, and length is in 1ft increments.
I'll need to trim all the panels them to length (taking off an inch or so). 2 panels I'll cut to width. I'll also need to cut the trim pieces to length.
I figure a total of about 60 linear feet of cuts. All are straight, and nearly all are square to the edge of the material.
The roofing is 29ga steel. Here's the manufacturer's product page: http://www.championmetal.com/Default.aspx?Redir=ProductTypePage&id=1&Type=Ultra-Panel#
My friend is storing an air compressor with me, so air-powered tools are an option. I'd need to buy fittings and an air hose, though.
I do own red (left) aviation snips, but for this much cutting, I think I'd buy yellow (straight) snips for ease of use.
The manufacturer gives this guidance:
Steel roofing and trim should be cut with nibblers, tin snips or a profile shear. Although Champion Metal of WA. does not advocate the use of a saw, the reality is many people use a power saw in some manner. There are two concerns when using a saw. First, be sure that no burrs are left on the ends of the panel. The rough edges are not protected and will rust. Second, the filings coming off the blade are hot and will adhere to the surface of the panels and these will rust. Be sure all filings are removed from the surface as they will rust and pit the surface of the sheet.
Should I just use hand-snips? Buy an drill attachment? A metal blade in a circular saw? Buy an electric- or air-powered tool? Try to rent something? Maybe the roofing dealer will loan a cutting tool?
Jay Bazuzi
  • 11,678
  • 33
  • 96
  • 143
  • Related: http://diy.stackexchange.com/questions/15236/which-cutting-style-avionic-snips-do-i-choose-if-i-have-to-choose-just-one – Jay Bazuzi Sep 30 '12 at 02:54
I used to use a 7 1/4" metal cutting wheel on a circular saw. Works good, but wheel wears down fairly fast. There are also some good shear attachments that mount on drills. I'd advise you to make the cuts on the end going to the top, not the exposed bottom. Definitely have some spray paint or primer to treat the cut end, because it will rust. If you put the cut ends at the top under your ridge cap, you will be fine. The other alternative is to buy your panels cut to length before they land on the job. Several manufactures cut to order such as Everlast Metal Roofing.
shirlock homes
  • 58,152
  • 84
  • 166
    Jay, I have installed over 100 metal roofs, so got a few more tips for ya. Install your strapping, starting at the bottom, 2 feet OC with an extra on top if needed. Put your drip edges on first. Stack four to six panels on top of eachother, properly orientated for anti siphon edges and top of panel. Snap a chalk line across the top panel to align to centers of your strapping and predrill the whole stack with 1/8" bit to get perfect placement and easy starts. Square the first panel on the roof to your drip line and put a few screws in. Place panels and secure. go back and finish screws. – shirlock homes Sep 30 '12 at 11:40
There's a couple of different tools you can use:
The best tool / way
1 - Electric shears and / or nibblers. These are in my opinion, the best tools you can buy. Shears work fine while nibblers are designed more specifically for corrugated or curved panels. If you're a professional, this is what you need to buy.
nibbler to cut metal roof shear to cut metal roof
Fein Nibbler link at Amazon
Trumpf Tools (second picture) also have great shears, but you can't buy directly.
You can buy "similar" tools on Amazon, for a lot less. I don't know how good they would be, but for a one time thing, it may be worth it.
Link at amazon
Other ways
2 - Regular long snips. The 12" Andy snips from this page are one of the best you can find. Considering its 29 gauge, you should be able to cut through like paper.
Link
If you want something even better, but I'd say requires a little more experience to use:
Link
3 - A grinder. But I personally wouldn't use it.
4 - Aviation snips for little notches you might need to make. You can try different brands, I have, but Wiss is a little more money, but still my favorite. I don't think you need a set like this, I honestly have never used the yellow ones. You can buy the green and reds separately and even angled ones that are helpful.
Amazon link
riseagainst
  • 560
The saw works good but you will also need long sleeves and safety glasses. I speak from experience. nearly lost my sight in both eyed from infection from metal fragments when cutting steel roofing.
skezix
You can make a good cutting blade for sheet metal roofing out of a cheap circular saw blade.
Go find your old used circular wood cutting blades, without carbide teeth, or buy the cheapest circular saw blade you can buy. There is no point in messing up a good carbide tooth blade. They can be easily re-sharpened.
Circular saw blades usually cut about 1/8 inch wide. If you look at them, you will see the teeth are angled outward to make the 1/8 inch cut. But the blade itself is approximately 1/16 inch wide.
So take the used or new blade and stick it in a vise. Use an angle (side) grinder to make all the teeth no wider than the rest of the blade. This is easy to do. If you do not have an angle grinder (like one a welder uses) then put the cheap blade in the circular saw and turn it against a grinding stone or grinding wheel. When you are done the teeth are 1/16 wide.
All the grinding will be on the sides of the teeth. Do not grind the teeth off of the blade , only the sides of the teeth. When you finish, the blade's teeth will be thinner, but the ends of the teeth are not shorter. This should take only a couple of minutes. Do not make the blade any thinner except at the teeth. This blade has no need of sharpening. It dulls up as soon as it hits the metal - and cuts fine.
Now you can mount the blade in the saw and cut the roofing metal, but you are only removing 1/16 of an inch, a much thinner and easier cut.
Metal roofing with ribs cuts easier from the back side(the down side when screwed to the roof). I use pencil lines, pop lines are too fuzzy.
You can run this thin blade forwards or backwards, but after it makes a few cuts, the teeth are not sharp and direction makes little difference.
This blade will last FOREVER. It will not need ANY sharpening.
YOU, however, WILL need earplugs. The easiest place to cut metal roofing is on the grass. The metal sheets slide around too much on a bench or table. Lay a 2x4 on the grass and hang the end of the metal panel over the 2x4. Now your blade is not digging into the turf as you cut.
I have cut painted and unpainted Galvalume metal roofing this way. If you get hung up or the blade is pinched by the metal, stop and adjust. The blade needs to keep moving so it does not get hot and mess up the paint on painted galvalume.
P.S. You can get clean edges by running a 4 inch angle grinding wheel along the edge where you cut. This should be done RAPIDLY, to just remove the burrs. If you stop moving, the grinder will dig in where you don't want it to. Don't push hard on the wheel - just lightly remove the burrs left over from cutting. This makes a nice smooth edge if your cut was straight.
I have found very little rust on these smoother cut edges and I live in a wet climate. I think the zinc in the galvalume migrates to the edge somehow.
j redou
The roofers I've seen working with metal sheet cladding have usually used an air or electric nibbler to cutting single sheets. Composite sheets (metal, insulation, metal sandwich) generally get cut with a carbide tipped circular saw.
In addition to a nibbler, I've also used a grinder to cut metal sheet, but as mentioned, it does usually leave a bit of a messy burr on the cut edge.
John
  • 2,410
