I need to put an adapter onto a ball valve at the end of a supply line. Do I need to shut the water off to the whole line?
Scott
  • 365
  • Does it required soldering? – Ack Mar 22 '20 at 17:40
  • Yea....attaching the adapter to go to the new bathroom. Going from copper to pex – Scott Mar 22 '20 at 18:22
    The pipe were you are soldering can't have water in it as it will absorb the heat and prevent a good (or any) connection. As long as your section of pipe is water free then you are good to go. – Ack Mar 22 '20 at 18:26
The ball valve can, I assume, shut off the flow where you need to attach the adapter. In that case just close the valve, attach your adapter, and proceed.
jwh20
  • 23,085
There are other options, one is to get a “pipefreezer”, a kit that freezes a section of pipe allowing you to work on the free end.
Solar Mike
  • 26,234
  • 57
