I have a plug for a wireless router that ends in two prongs (no ground). Is it safe for me to plug this into an extension cord that has the ground prong, which would be left empty? I believe it is but want to double check.
15Generally speaking I believe plugs were designed to mechanically allow things which are safe, and prevent things which are not. Therefore you cannot plug a 3-prong into a 2-prong, but the other way is safe & allowed. – StayOnTarget Mar 23 '20 at 15:11
6@UuDdLrLrSs True, but a 2-to-3 prong adapter ( a "cheater plug") is unsafe in certain configurations even though it's a perfect mechanical fit, so "if it fits it's safe" isn't a perfect rule of thumb. – Nuclear Hoagie Mar 23 '20 at 16:35
5@NuclearWang I think "rules of thumb" are imperfect by definition – StayOnTarget Mar 23 '20 at 16:37
@UuDdLrLrSs except for the rule that no (human) person has more than two thumbs! – Dai Mar 24 '20 at 11:36
@Dai Usually. But you never know… – glglgl Mar 24 '20 at 13:34
https://www.healthline.com/health/polydactyly @Dai – Dawood ibn Kareem Mar 25 '20 at 02:59
2This question needs to qualify that it is talking about US plugs. For the UK, this would not be safe nor easy. The socket protector would have to be levered back manually & a 2-pin plug would then have to be forced into a socket not only the wrong shape but also the wrong size. You can buy 2 - 3-pin semi-permanent adaptors for pence. – Tetsujin Mar 25 '20 at 09:49
Yes you can safely plug the appliance into a 3-wire cord and plug set, as long as that is the factory installed cord and plug on the router.
Appliances that are double insulated do not require an equipment grounding conductor to earth because the live electrical parts are specially separated/insulated from the case in a way that prevents any single failure from electrically charging parts that the user can touch.
There should be the words "double insulated" on the chassis, and/or this symbol:
- 35,093
- 31
- 55
1Just to put this more in layman's terms, grounds on plugs are so that the outside case and buttons don't shock you. You (generally) only need them if the case is made of metal. If your router's case is plastic it doesn't need to be grounded. – SaSSafraS1232 Mar 24 '20 at 16:23
1@SaSSafraS1232 You’re leaning hard on that “generally”. Some plastic cases include metal screws. The best thing to understand here is that if the equipment required grounding it would have a way to ground it like a ground pin. An extension cord with or with out a ground hole doesn’t change that any more than an outlet with a ground hole would. In other words, the requirement comes from the plug side. Not the socket side. – candied_orange Mar 24 '20 at 18:22
@candied_orange you're really over-complicating this, but metal screws are fine as long as they're not coming into contact with the electronics. Most consumer electronics stuff that doesn't have a ground on the plug is assembled with metal screws that go from one side of the case to the other and don't contact the electronics. The electronics are then mounted with internal screws into the plastic that are not accessible from the outside of the case. – SaSSafraS1232 Mar 24 '20 at 20:16
@SaSSafraS1232 safety measures are about when things go wrong. Not when they go right. This question isn’t about how to build them. It’s about avoiding circumventing them. – candied_orange Mar 24 '20 at 20:18
If the power cord on the router is one of the modern type like this ...
... with one blade wider than the other then you have a polarized plug with the neutral routed through that wider prong. You want to make sure to properly orient the plug at the extension cord so that the wider blade goes into the wider slot.
Note that there are lower quality extension cords where it is possible to force in the plug wrong way around because the molded plastic will just stretch. This is one reason that you now see cords that have hard plastic around the holes that is then overmolded with the more flexible material.
- 64,093
- 7
- 63
- 142
7Tim Allen had a stand up bit about tools and Sears. He says he bought a grinder explicitly to grind the wide prong down so it would fit both ways. Lol. – Mar 23 '20 at 17:20
23
2TIL, "This is one reason that you now see cords that have hard plastic around the holes that is then overmolded with the more flexible material." – Doktor J Mar 23 '20 at 23:44
3@DMoore should do - but it means live and neutral are swapped. So in a simple case like a desk lamp, the bulb's holder-socket is on the live wire with the switch on the Neutral side. Thus with the switch OFF and the plug flipped over, the exposed terminals under the lamp/bulb are live and a shock-risk when changing the lamp. – Criggie Mar 25 '20 at 18:32
In general, yes; in terms of grounding this is no different from plugging such a cord directly into an outlet.
Where you need to be careful is that your extension cord is rated for the power that your device is going to draw, but this has nothing to do with two-prong vs. three-prong plugs. (Also, grounded extension cords are typically rated for more current than devices with two-prong plugs typically draw, and even then, I think almost all cords are rated for at least 1A, which means you will likely only need to worry about devices that draw more than 1A / 100W. Edit: looks like you're unlikely to find less than 10A, so up to ~1000W should be safe, but if you're paranoid, stick to 500W unless you know the rating.)
- 229
- 1
- 5
You can buy extension cables only good to 1A? That sounds horribly dangerous. Is this US again? Everything here has to be good to 13A, UK. – Tetsujin Mar 25 '20 at 15:21
Yes, US. I actually don't know what a typical "cheap" extension cord can handle, just pretty sure it's *at least* 1A. It might well be 10A. (Actually, poking around on Amazon for cheap cords, looks like 13A may be the minimum here also. I know the heavier, 3-prong cords have different — from each other — ratings though.) – Matthew Mar 25 '20 at 16:15
For example, [here](https://www.amazon.com/dp/B00REWQYLG) is an 18 AWG, 10A cord, and [here](https://www.amazon.com/dp/B073ZMW2QX) is a 12 AWG, 15A cord. Both 10' long. – Matthew Mar 25 '20 at 16:20
In the UK there is only a single standard for consumer mains. Everything must be rated 13A, even if fused for less, the underlying circuitry must be 13A. tbh I have no idea what these different AWG things mean, there's no real equivalent over here. Basically, things here are designed so you don't have to read the small print before plugging anyhting in. – Tetsujin Mar 25 '20 at 16:21
AWG = American Wire Gauge, i.e. how thick the wires are. I'm sure you have an equivalent, just in different units. (AWG is kinda stupid, especially as smaller numbers are larger diameter. I think this is because the units originate from the size of the shot such that you could pack that many into a standard shell.) Even if you never see other than one size in a typical household, mains and industries will need larger wires. – Matthew Mar 25 '20 at 16:23
Sure - I kind of knew what it 'stands for' but not really what it 'means' ;) For contractor cabling we have different gauges, lighting 5A vs regular 13A vs high power 30A etc - but you buy this by 'amperage' not by 'gauge'. Once it's at the consumer 'plug it in a socket' level, it's all 13A. – Tetsujin Mar 25 '20 at 16:27
& of course, for 415v 3-phase & upwards, that's a whole different thing. – Tetsujin Mar 25 '20 at 16:28
Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/105944/discussion-between-matthew-and-tetsujin). – Matthew Mar 25 '20 at 16:30
1Yeah, my 2kW router doubles as a room heater :-)). It's glowing in the dark! it needs to be 3 feet away from combustible surfaces! It heats my porridge in the other room with its microwaves! – Peter - Reinstate Monica Mar 26 '20 at 13:36
