Background
My home has vinyl siding installed over the original Masonite/hardboard siding. The vinyl siding wasn't installed correctly (don't caulk your J-channel, folks, or the nailing flange becomes the weep holes - into your home!) and it led to some massive rot around the foundation of my house. I wound up reframing the bottom half of my house it was so bad.
During that time, I had to remove the windows (because the framing around the windows had rotted away) and needed to reinstall them. However, the rot was only on the bottom portion of the house. I didn't need to remove any more siding than the bottom 6 feet. However, I needed to remove ALL of the siding, including the Masonite siding, to get at the sheathing and studs, and all of the Masonite siding was rotted, too.
Original Wall section
After removing the Masonite siding, I was left with a problem. The new windows had a built-in channel for the vinyl siding, but if they were installed flush to the sheathing then the vinyl siding wouldn't terminate correctly because the rest of the Masonite siding had built it out too far. I could have removed the Masonite siding from the entire house (this is really what I should have done), but the entire process was exhausting and I didn't really have the time to re-side the whole house, so I used some pressure-treated material to build the wall out an inch:
Current wall section
My concern with just leaving the Masonite off was that it was still on the upper 10 feet of the house, and it'd cause the vinyl siding to "suck in" along the bottom 6 feet. I used the pressure treated material to build out around the windows, but I used rigid foam insulation to build out the bulk of the exterior wall, after wrapping the sheathing with Tyvek.
Now I'm to the point that I'm ready to (have time and money to) replace the vinyl siding, but I'm stuck with the decision I made previously - I could pull all of the windows, remove the P/T lumber, and re-install them, but it's too costly at this point to do that.
My major concern is with rot or water damage between the rigid foam insulation and the house - I just don't see how the wall section would ever dry if (when, it's always when) water manages to get behind the rigid insulation.
Question
I was wondering if it could be possible to strip the Masonite siding off, install pressure treated furring strips, and install the siding attached to the furring. I had originally dismissed this idea because I was worried wind would get behind the siding and rattle it, but then I saw this ProTradeCraft video where they're installing 1x3 furring strips with the intent of standing the siding off.
Proposed wall section
I used 5/4 pressure-treated decking when I built the windows out, so it's actually a 1 inch thickness, putting me about 0.25" further away from the wall than the ProTradeCraft video. Would this be okay to do?
What is an acceptable gap between the siding and the wall sheathing?
Chuck
  • 559
So I've looked around online quite a bit more since asking this question, trying to see if I can find a building code or some other standard that will give a concrete answer. I didn't find a building code, but I did find some vinyl siding installation guides and, without an explicit building code statement, I would always defer to the OEM installation guides.
The Certainteed installation manual says, on document page 31,
Tips for applying wood furring
If you are working on an older home with noticeably uneven walls, you must correct this condition before proceeding. If not corrected during preparation, this uneven surface will produce a wavy appearance in siding applied over it.
For best results, space horizontal furring strips 12" on center. Do not exceed 16". To correct an uneven wall, use furring strips (and wood shims if necessary) to eliminate low spots.
NOTE: You must apply rigid sheathing over furring.
(Emphasis original). They then go on to give the following graphic (document page 32):
Certainteed furring installation
This graphic specifically goes with the installation over concrete or stucco, but clearly shows a sheathing over the furring strips.
The Plygem installation manual says, on document page 17,
Step 4
Install furring in areas needing straightening and leveling. Apply rigid sheathing to cover and level the furring strips. Do not apply vinyl siding directly to furring strips without sheathing, because the siding may conform around the furred areas causing an uneven appearance.
(See Fig 2)
And then gives Figure 2 as:
Plygem furring installation
Again, clearly showing a sheathing ON TOP of the furring strips. Georgia Pacific siding seems to use the same document (warning: direct download).
The Vinyl Siding Institute's 2018 installation guide seems to be a little more ambiguous, stating on document page 18,
Make sure that any furring strips are thick enough to provide this penetration depth, or cover them with wood sheathing to provide the needed depth.
The "or" there is what makes it ambiguous to me, but the top of that page also clearly states:
A flat, level wall surface is necessary for proper installation of vinyl siding.
They also give the following graphic on document page 15:
So, ultimately, I think the decision here would be to use standard 1x3 furring strips (NOT pressure treated), such that they're dimensionally 0.75" thick, and then to face those with 0.5" foam insulation. Some reviews have said the furring strips are actually 5/8 thick, not 3/4, but it should be close enough for the siding to fit into the window trim (though I'd definitely dry fit one section before investing in a whole house's worth.)
Finally, regarding the NOT pressure treated furring strip, the general practice of installing the furring strips to create a cavity seems to be referred to as creating a rainscreen, and the author of that article makes a comment saying,
Using pressure-treated lumber is not only unnecessary -- it often requires the use of expensive stainless-steel fasteners.
Lots of researchers and ordinary builders have removed siding and inspected furring strips. The furring strips stay dry.
If a wall has rotting furring strips, something is seriously wrong with the wall design or installation. Rotting furring strips would usually be a sign of a serious flashing error.
Finally, I'll note that the article and the video I linked in the question all seem to be using furring strips without a sheathing as part of a wood siding installation. Again, all the sources I could find on vinyl siding are OEM installation guides and they're all uniform in their statement:
You must install vinyl siding on a flat surface. Attach sheathing to furring strips if you need to use furring strips.
Chuck
  • 559
  • Excellent follow up, thank you. I learned today. Please mark your own answer as accepted, this is general practice, encouraged and helpful for others – Ack Apr 17 '20 at 14:53
  • @Ack - I will, but there's a "cooldown" of sorts; I can't accept my own answer for another 22 hours. Thanks for the comment :) – Chuck Apr 17 '20 at 15:47
I don't believe that there is a minimum or maximum. If there is then it is buried in the part of the code that architects are interested in but not me. The siding is the protective layer against the weather and is also a decorative covering. The siding is not part of the structure of the building, it serves no structural purpose and therefore it doesn't matter how far away from the sheathing it is located, only that the sheathing is protected from the elements.
Ack
  • 5,709
  • `it serves no structural purpose and therefore it doesn't matter how far away from the sheathing it is located, only that the sheathing is protected from the elements.` Okay sure, but what about wind getting behind the siding? Is there any validity to my concern here (rattling siding) or will there be no issue if it is nailed off on the appropriate interval? – Chuck Apr 16 '20 at 14:59
  • If there is distance between the siding and what is behind it, how can it rattle? How would wind get behind the siding? Is there a flaw somewhere? – Ack Apr 16 '20 at 15:44
  • Wind could get in, and could rattle (I think, at least) where the sections overlap and the interlock between sections between the furring strips. I guess I'm mostly concerned about the siding being unsupported between furring strips and the wind being able to move easier with a larger air volume behind the siding. – Chuck Apr 16 '20 at 15:55
  • OIC, yeah that is a valid consideration for vinyl, it really has very little support in that direction. It sounds like we've circled around to you finding the answer in yourself, you don't think it's a good idea because of the noise that will occur during higher winds. In that sense, it's not 'ok', you need to support the siding more fully than just the furring strips to have it ok for you. You might connect the vinyl manufacturer about this issue, they might have some minimal support guide lines – Ack Apr 16 '20 at 16:26
