I'd like to build a fitted bookcase into the corner of a gable end, such as in this mockup. Excuse the poor attempt, I've never used SketchUp before.
Obviously they should show shelves/dividers etc and a 45deg angled corner section between the two walls, but I figure this is good enough for this question.
I'm undecided at the moment whether the units would stop in line with the edge of the door, continue over the door (as depicted) or (very possibly) go down the other side of the door as well.
My semi-plan is to buy an Ikea Billy bookcase unit or two (probably the large corner unit they do), and see if I can fit it into the corner by cutting bits off and melding other bits on.
Maybe that's too ambitious and it'd be easier to work with two separate units and forego the 45deg unit between them, and just have them butt up at 90deg and have some wasted space hiding behind.
I have a "can do" attitude, am happy to buy some tools, but a decided lack of woodworking skills/experience.
Is this quite trivial? What tools and techniques are the best way to cut laminated chipboard (or whatever Billy is constructed from) without chipping and ruining the outer layer?
I've never owned a Billy before so at the moment I have no idea what they're made from or fasteners Ikea use and how easy it'd be to relocate them, etc etc.
Thanks!
Codemonkey
  • 551
  • Who is billy, I have no idea what a billy bookcase is. Do not put anything to close the doorway so if you have to modify, replace door you do not have to remove billy. Actual photo of the space might help. – Alaska Man Apr 23 '20 at 16:29
  • I assume you know exactly what I mean, but either way, valid point, I've added the brand name as well. – Codemonkey Apr 23 '20 at 16:31
  • Are you laminating the ceiling with the same look as the bookcase or are you keeping the ceiling a painted look within the book case? Is it a door or doorway? Swing into the room or out of the room. – Fresh Codemonger Apr 23 '20 at 16:39
  • Door. Swings in. I imagine I'd only fit the bookcase up to the architrave, not to the door itself! As for the other question, it's one I've pondered myself. I assume you mean for the top shelf of the left hand unit. I haven't decided yet, and could be swayed by which was easier, if someone explained why! – Codemonkey Apr 23 '20 at 16:45
  • What is the height of the left wall to where the garble meets the wall? – Programmer66 Apr 23 '20 at 16:49
  • Ready to assemble furniture is typically highly dependent on all manufactured parts to fit together as designed for stability. However, if you can match the finish you can build the oddball parts yourself. I did that with my kitchen 20 years ago. Most cabinets Mills Pride (Home depot at the time stocked flat pack of all typical cabinets) but I built 2 myself to fit the oddball areas of my kitchen and they all look the same. – manassehkatz-Moving 2 Codidact Apr 23 '20 at 16:49
    I wouldn't even consider the 45 degree aspect given your starting knowledge. The two wall aspect significantly complicates it. You'll need to worry about square, level, plumb for the two walls - all will require adjustment. Do-able but expect some headaches. Keep the ceiling painted in the bookcase. For one thing the angle means that piece will be larger than a shelf so you'd have to get the material somewhere else. The sides are fine I'd plan to leave them 1" shy of the ceiling - professional cabinet people allow 2" for out of planes and hide that with end gables. Plan for 2". – Fresh Codemonger Apr 23 '20 at 16:50
None of this would be considered trivial. For example, just to do the left bookcase conversion for the 45-degree top.
After cutting off the top of the cabinet to make the 45-degree angle, you would not have a top piece to place on top. The top board is now too narrow because it is at a 45-degree angle. The first issue is how to replace or extend the depth of the top to fit the top of the case. The new cut on the sides no longer have the holes for the cam screw. You would have to replace the original cam screw with other fasteners to join the new top to the sides.
The corner unit adds further complications.
If possible, I would look to find a wall unit that fits up to the gable.
I just modified a full-size pantry cabinet to fit under a stairwell with the angle going across the full width of the cabinet, and it is not trivial.
Programmer66
  • 2,744
  • Are the cam screws not easily relocated with a spade/forstner bit? – Codemonkey Apr 24 '20 at 16:19
  • Yes, with a Forstner bit, but requires precise placement and alignment with the matching screw. I would use pocket hole screw on the top replacement. Remember, if the side is cut at a 45-degree to match the slope, the top piece will not have the depth to cover the top. an extension would have to be added to the top piece. You also have to consider if you want to cut the front edge so the edge is vertical. Cutting the front edge would remove the finish on the edge. – Programmer66 Apr 24 '20 at 17:40
  • How high is the wall from floor to the slope? – Programmer66 Apr 24 '20 at 17:42
You can't. Well you can but you can't create this in a "right" way.
Let's understand that while IKEA bookshelves may look good, they stay together based on a series of locks and joints, and for the most part they are MDF crap. I have IKEA crap in my house too and I have modified some of it a bit - shelves into a bench.
But you have two issues in your diagram that you cannot solve with IKEA shelving:
  1. You cannot remove the corner or the shelves will literally fall apart with any weight or movement. These are not solid wood bookshelves that are joined properly. The corner piece holds two sides to a 90 degree angle. Destroying that kills the integrity of the unit.
  2. You can't expect to cut MDF with a finish layer and expect the finish layer to stay in tact or for the the MDF to stay in good shape.
The most plausible thing you can do here is create a 45 degree shelf unit above the Billy bookcase and slide the bookcase in under in full tact. However creating this is rather simple but making it look like that it belongs to the Billy bookcase is going to be really difficult including matching the finish and trimming out the entire "gap" between it and the IKEA bookcase. What makes this even harder is that the side of the bookcase is exposed.
Also just looking at the plans "the top shelf" doesn't make sense. Books wouldn't sit on a shelf that had a 45 degree angle (unless you have books shaped like a triangle). You might as well just let the shelves sit right below this. If the Billy shelves are too big you need to find ones that will fit better. If you want it really to look like this then you should think about using real wood.
DMoore
  • 47,764
  • 190
