13
So I was draining the tub in my 1920's era condominium a moment ago when I noticed a substantial amount of water pooling on the floor next to my tub. I soaked it up in a hurry but then I noticed a little more bubbling coming up from under this silver mystery plate next to the tub:
I've used this tub many times before but never had an issue. As soon as the tub had fully drained out the water stopped coming out from under the plate.
What is happening here? I'm totally befuddled. What should i do?
JACK
  • 78,739
  • 72
  • 188
OldCondo
  • 449
    don't stand there befuddled, remove the lid and look inside – jsotola May 03 '20 at 01:03
    ...and don't ignore this. Its a sign that something is wrong. – Criggie May 03 '20 at 11:42
    Very likely the tub drain is clogged with hair and needs to be augered out. – Hot Licks May 03 '20 at 14:41
  • You may be able to clear out the hair with a plunger (and if that works you can ignore the metal plate). I like to use the plunger whilst water is draining, so I am pushing around water rather than air. – joeytwiddle May 04 '20 at 04:46
  • While in this case it seems clearly the correct route, blindly removing covers is often a good way to cause a tremendous mess. – ti7 May 04 '20 at 17:14
    Sorry for the delay! I was wrapping up another home project crisis at the same time that was taking priority which I've since resolved. This one was on the backburner. I will address this tomorrow and update everyone. – OldCondo May 05 '20 at 18:35
That's a cover for your drain clean out. If water is leaking out of there then either the threaded cap below, if there is one, is loose or there is a blockage starting to form and the drain water is starting to backup because it can't go down the drain fast enough. There could also be a drain plug under the cover that has deteriorated and is leaking. You can undo the screw on the cover and check it out and see what the problem is. Take some pictures. Then come back here for some solutions. Here's what the drain plug would look like.
JACK
  • 78,739
  • 72
  • 188
12
Buildings of that old often had an external drain open / shut device for the tub. Rather than being built into the tub itself, there would be a lever or pull-up/push-down plunger mechanism next to (and outside of) the bathtub itself that could be used to close the drain in order to fill the tub. That cover plate is located exactly where that drain mechanism is commonly found. One example can be found here How does an external tower style bathtub drain work?.
It is possible that in your situation, when the bathroom was renovated at some point, a new bathtub was installed, but the old plumbing kept, and a cover plate put over the hole in the tile where that mechanism used to attach to the drain. Through the old plumbing, water is now being forced through that cover plate (possibly in response to a clog elsewhere in the drain as already mentioned).
Picture of external bathtub drain mechanism from another thread
ponimello
  • 121
    If I had to guess, the tub is original, but has been recoated. The waste tower was removed in favor of using rubber stoppers. So snaking under the cover plate would be worthwhile. – gbronner May 04 '20 at 01:31
