I've lost power in part of house .all breakers have 120v .it starts from kitchen ceiling fan to living room wall,guest bathroom,guest bedroom.just lights.
Asked
Active
Viewed 50 times
Does this answer your question? [Weird Power Outage in Certain Rooms- Condominium](https://diy.stackexchange.com/questions/178240/weird-power-outage-in-certain-rooms-condominium) – Machavity May 04 '20 at 15:34
As the duplicate notes, you've almost certainly lost one leg of your electrical feed. Call your utility to report it. – Machavity May 04 '20 at 15:35
@Machavity: OP claims that all breakers have 120v. If this is accurate then problem is not a lost leg, but must be downstream from the service panel. – A. I. Breveleri May 04 '20 at 15:56
Are you stating that multiple circuits have lost power? – Programmer66 May 04 '20 at 16:02
Haven't lost any in panel.120v going through all breakers. – Jack Rickman May 04 '20 at 17:45
Clarification on my question, the fixtures that are not working, are they on one circuit or multiple circuits? – Programmer66 May 04 '20 at 18:01
1Hi, you need to provide a LOT more information for anyone to help. How many different breakers feed the various light fixtures involved? Did it used to work, and if so was there any sort of event - lightning, etc ? How are you determining that the breakers' outputs are truly 120V -- relative to Earth Ground, or to neutral returns, etc? – Carl Witthoft May 04 '20 at 19:05
