My sons metal A-Frame swing has started twisting to the point that instead of swinging in the usual pendulum 12 to 6 motion, he ends up going at 10 to 4 (if that makes sense). I’ve tried moving the legs further apart, and closer together and levelling into out the brackets at the top that the rope hangs on but nothing I do seems to change anything.
Any help would be much appreciated, it was the one activity that kept him quiet during lockdown!
Phil Swain
    Does it swing that way if another person uses it? You would want to rule out any personal effect caused by the user before taking radical steps... – Jimmy Fix-it May 16 '20 at 16:34
I built a large swing for my grand children what I learned having the A frame legs wider at the base about a 15 degree angle and then having the swing supports , chain, or rope a similar spread did the trick.
Originally I had the supports the same width as the seat and they would end up swinging at an angle, I went and measured several swing’s at our local park and found that they were wider at top, after moving the brackets out the swings now swing true.
I had tried all kinds of things changing from chains to ropes changing the length I had even tried taking the base out of level (this was a dumb thing and a lot of work)
After everything the wider at the top did the trick it kind of makes sense but I thought the swing needed to go straight up after measuring 2 different swings at the park I tried it and what a difference , it doesn’t affect their ability to get going or no one ever noticed but it did stabilize the travel.
