Will a water and soap solution (one tsp of soap in a cup of water) cause a pipe to rust more than BrassCraft Gas Plastic Water Heater Gas Leak Detector?
Asked
Active
Viewed 775 times
joe
- 510
- 2
- 7
- 21
I doubt there's a list of ingredients on that bottle (unless it has an MSDS), but I'd be shocked if it were anything _more_ than soapy water... It probably has instructions to _not_ shake it, as that will cause the soap to bubble. – FreeMan Jun 17 '20 at 13:06
1Usually also a bit of glycerine for more bubble persistence (take longer to pop, so easier to see.) Which is, of course, also easy to DIY. Or you can get a premade version that comes with a bubble-blowing wand at "mass produced children's toy" pricing. – Ecnerwal Mar 29 '23 at 15:36
Absolutely dish detergents with chlorides corrode gas line metal! My lines were installed 5 years ago and the residue the plumbers’”soapy water test” left behind ate holes in the metal. Use what the gas company recommends.
JACK
- 78,739
- 18
- 72
- 188
Are we talking about black iron pipe here, brass fititngs as you'd find with CSST, or copper tubing? – ThreePhaseEel Dec 03 '22 at 16:48
Rinse and dry after testing if you are nervous. Dawn attests that it is non-corrosive.
Fredric Shope
- 4,389
- 14
- 34
