18
I'm comfortable with the process of creating and joining wood with dowels, but I'm not sure what size dowels to use in which cases? Specifically, I'm working with 1" thick stock (3/4" actual), what size should I use?
What are the other sizes and lengths of dowels used for?
Are there any recommended grouping or spacing for wood dowels?
Sparafusile
  • 335
The best work I know of on the topic was written by Tage Frid (see http://amazon.com).
The approximate rule-of-thumb, iirc, is to use a dowel no more than 3/8 the thickness of the wood to be joined (and not less than 1/4 the thickness).
Expansion
For example, if you are joining 5/4 boards (finished thickness 1"), the dowels should be between 1/4" and 3/8" in diameter.
Likewise, if joining finished thickness 3/4" boards, use between 3/16" and 9/32" diameter dowels.
This presumes, of course, you're joining the boards on the narrow dimension (e.g. making a door frame).
warren
  • 941
  • This is the [publisher's page](http://store.taunton.com/onlinestore/item/the-complete-illustrated-guide-to-joinery-gary-rogowski-070535.html) for the book I'm assuming you're referring to. Also as an [ebook](http://store.taunton.com/onlinestore/item/the-complete-illustrated-guide-to-shaping-wood-lonnie-bird-ebook-077951.html). – Dennis Williamson Sep 30 '10 at 18:10
    @Dennis Williamson - actually, I was thinking of http://www.amazon.com/Tage-Teaches-Woodworking-Step---Step/dp/1561588261/ – warren Oct 07 '10 at 18:49
  • So, a 4.5mm dowel for a 12mm thick board? – Matt Fletcher Aug 18 '21 at 17:10
  • @MattFletcher - something in that ballpark, yes – warren Aug 18 '21 at 19:37
12
When dealing with joinery I typically always deal with thirds. So I'd get whatever is closest to 1/3" that I can get. 3/8" is probably good for this, 5/16" even better. Thirds is a pretty good rule of thumb especially for furniture sized joinery.
This can be applied to all types of joinery such as mortise and tenon, splined miters, bridle joints, etc.
Cody C
  • 2,811
  • +1 also. 1/3 is easier to remember, though with full-size lumber 3/8 is sometimes easier to compute and measure. :) – Alex Feinman Sep 26 '11 at 17:34
    Sat in on a class of Roy Underhill's this weekend. His opinion is to use something at least 1/3rd of the thickness of the piece but less than half. – Cody C Oct 03 '11 at 19:09
    I don't see how this is the correct answer. If the actual thickness of the wood is 3/4" and the dowels should be 1/3 of this, shouldn't the dowels be 1/4"? A 5/16" dowel would be 1/16" too large, a 3/8" dowel would be 1/8" too large. – Aaron Cicali Jun 01 '20 at 20:02
  • @AaronCicali Agree with rule of thirds but math is wrong. 3/4" * 1/3 = 1/4" – franklylately Sep 28 '22 at 16:31
  • @franklylately Isn't one third of three quarters equal to one quarter? We seem to be in agreement. Will you please clarify which math is wrong? Thanks! – Aaron Cicali Sep 28 '22 at 16:36
  • @AaronCicali Can't edit. Your math correct. Cody C is wrong. – franklylately Sep 29 '22 at 03:23
  • @franklylately Thanks for clarifying. Perhaps 1/16" will work with some wood. Possibly it could split something if the wood is hard enough. Just a guess. – Aaron Cicali Sep 29 '22 at 14:30
