My gridded windows (small pane, divided light) were masked for too long and now the tape is brittle and leaves residue.
I'm using a razor blade to scrape and Goo Gone to remove the glue but is there a better way?
Mix dish soap and water to make a VERY slippery substance. Then a common $2 razor scraper, being careful to make sure you change razor blades often and it never gets dull. If it gets dull it could scratch the glass.
The purpose of the soapy water is to make sure the razor blade glides across the glass.
It's quick work, unless the masking tape is still tacky. If it is, lay fresh masking tape across it, rub down and peel.
By the way, the razor blade method also works on primer and paint. You didn't actually need to mask the glass at all. You could have just overpainted the glass wherever you wanted to, and then used this same technique to lift the paint. It's actually much easier than what you're doing now.
Returning to answer my own question a year later.
I had received advice that if I left the tape on for more than a month that it would be very difficult to remove. That's completely true. However, if you can leave it for about a year or more then the adhesive becomes friable and can be much more easily removed.
It's now about 18 months since the tape was put on the windows.we were able to clean it all off in about 2 hours today.
My windows are divided light style windows with six squares in each window. Attempts last year took about an hour per square. After waiting a year it took about 5 minutes per square using the same method.
Not everybody is willing to just keep the tape on their windows that long but if you are, then even more time after the first 3 months or so will make it easier to remove.
