Non-engineer here, I'm trying to adapt a typical "A-frame swingset design" (like this https://www.instructables.com/id/Free-standing-A-Frame-Swing-Set/) to be a small set of traveling rings for the kids (inspired by these: https://travelingrings.org/).
To that end, I'd like to make an A-frame swingset that is relatively high (10 or 11 feet to the bottom of the swing beam, as opposed to the usual 7-8 feet), and relatively long (16 feet swing beam without a supporting A-frame in the middle). The reason why the lack of middle support is important is because of the large amount of clearance that traveling rings require.
This readily available swingset bracket (https://www.amazon.com/Frame-Brackets-Complete-Mounting-Hardware/dp/B01M28VV0N/ ) supports a 4x6 beam , and I've seen comments from people successful supporting 12 foot spans with this type of bracket, even though the manufacturer recommends a 10 foot span.
My question is three fold:
  1. Would a 4x6 beam safely support a 16 foot span for this type of application? (assuming standard treated lumber like redwood or pine, not glulam or lvl) This question was somewhat addressed here: Is this swing beam safe? And my conclusion is that a 4x6 is iffy.
My primary question, assuming the that a 4x6 is a risk, is the following:
  1. If not, would a 4x8 beam which was notched at both ends to fit the 4x6 bracket support a 16 foot span? (with the same assumption around non-engineered lumber)
  2. If no to both #1 and #2, would a 4x8 beam on a different type of bracket be able to support this span?
My main concern is deflection & buckling from force applied in the center. The largest kid currently weighs 70lbs, and there could be as many as three kids on the set at a time, swinging vigorously and possibly in sync.
Final followup question:
  1. In the A-frame design from instructables that I linked to above, the a-frames are supported by a cross beam. Would it compromise the integrity of the design if the cross beam were moved lower to the ground? I'd like to keep the center of the A-frames open if possible, in case the kids swing through them. My intuition is that it actually strengthens the design if the cross beams are lowered, but just wanted to get a sanity check on that.
Thank you in advance for any help you can offer to vet the safety of this design.
john_fries
  • 111
  • This might help: https://diy.stackexchange.com/questions/49086/is-this-swing-beam-safe. This other question also has a lot of information about how to calculate safety: https://diy.stackexchange.com/questions/8112/how-much-load-can-a-wood-board-support-if-it-is-supported-only-at-the-ends – IronEagle Sep 19 '20 at 04:24
    Does this answer your question? [How much load can a (wood) board support, if it is supported only at the ends?](https://diy.stackexchange.com/questions/8112/how-much-load-can-a-wood-board-support-if-it-is-supported-only-at-the-ends) – Ack Sep 19 '20 at 04:57
  • @Ack The "How much load can a (wood) board support?" question was my first stop, but I'm having trouble doing these calculations with any degree of confidence. The sagulator app that was linked there seemed to indicate an acceptable amount of deflection with a 4x8 and an unacceptable amount of deflection with a 4x6, but I don't know if I'm using it right. – john_fries Sep 19 '20 at 13:46
  • @IronEagle thanks for the helpful links. I actually did review the "Is this swing beam safe?" one you linked to, but it only seemed to apply to a 4x6 beam (which I'm mostly already convinced is iffy), whereas my primary question is in regard to a 4x8 beam. – john_fries Sep 19 '20 at 13:48
  • john_fries On longer support beams the deflection will control design, not strength, so it sounds as if it is working correct based solely on the information in your comment – Ack Sep 19 '20 at 15:59
  • One major difference between the linked design and your application is that in the design the major sideways loads are parallel to the A-frames, while in your application there will be significant side-to-side forces perpendicular to the frames. I don't think you can use the brackets in that application. – IronEagle Sep 19 '20 at 16:39
  • @IronEagle The brackets are angled so that the posts point somewhat outward, so as to resist a certain amount of lateral force (without the angle I think the strucutre would be highly vulnerable to a parallelogram effect), but I agree that it could still be an issue. Do you have any thoughts on what kind of design could be better for this? – john_fries Sep 19 '20 at 16:42
  • If you joined just the wood, you could add a bit more angle in - something like https://diy.stackexchange.com/questions/94177/a-frame-bracket-for-4x8-swing-beam might work. I'm not sure how much of an angle is necessary. If possible, wooden braces a couple feet out from the joint might even be enough with the original bracket - something like the "C" piece here: https://howtospecialist.com/outdoor-furniture/how-to-build-an-a-frame-swing/ How far down will the travelling rings be hanging from the beam? – IronEagle Sep 19 '20 at 16:52
0 Answers0
