I have a top loader washing machine. When it's done washing it keeps dripping from the top fill valve, where the water fills up the drum.enter image description here
mark f
  • 2,295
The Solenoid Valve is leaking. It is an easy repair if you are comfortable with disassembly and re-assembly of the machine. example of valve
It should be about a $20-50 part depending on your machine. It may be possible to replace the soft goods in the valve and repair it, but its probably not worth it as all the work is in taking the machine apart and putting it back together.
mark f
  • 2,295
    Although I agree an easy job it may be something like a small chunk of crud or even a fine piece of plastic on the seat swap out should be 100% fix but disassemble and clean the solenoid would only take time, it might be a good plan to get the new assembly then try the tear down if you damage the assembly toss and install the new if repaired return the unused part. – Ed Beal Sep 29 '20 at 05:49
  • Hey Mark do you have the link to the part I need I added a picture what's the model number excetera thanks. – Douglas G Johnson Jr. Sep 29 '20 at 11:41
  • here is the non- OEM part: https://www.amazon.com/Clothes-Whirlpool-Kenmore-Frigidaire-Electrolux/dp/B074124N36/ref=asc_df_B074124N36/?tag=hyprod-20&linkCode=df0&hvadid=198070787462&hvpos=&hvnetw=g&hvrand=11235925285679360497&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030241&hvtargid=pla-362155928043&psc=1 – mark f Sep 29 '20 at 15:05
  • here is the OEM replacement: https://www.genuinereplacementparts.com/estate-etw4400wq1-water-inlet-valve-genuine-oem – mark f Sep 29 '20 at 15:10
