Looking around for a spray gun for my woodworking projects, I've found this one. This spray gun perfectly fits a couple of my requirements, so I'm seriously considering buying it.
However, I'm in doubt because of one thing that is mentioned in the description:
NOT SUITABLE FOR WATERBASED MATERIALS
And since I'm a total newbie in painting, I've decided to ask a couple of questions here:
  • What are pros and cons of water-based vs solvent-based paints?
  • Will I lose much by having a spray gun not suitable for water-based materials?
You never got an answer so I will give you a simple one. I'm not a painter and just have a small amount of general knowledge...
Pros and cons of water-based vs solvent-based? Well a simple answer would be that water-based is easier to work with, easier to clean up, better for the environment, and healthier. Solvent-based is tougher to work with and clean up, not so good for the environment, but generally considered better and more durable. Often most professional or factory finishes are solvent-based.
ryanwinchester
  • 2,763
