I cant get this lever off to take the face plate off. I took off the screw behind the lever but still won’t come off.
Asked
Active
Viewed 79 times
Adam H
- 1
- 1
Do you mean the "lever"? You wrote "leveler" twice. Once that screw is out (or loose enough) the lever should pull off. – isherwood Nov 10 '20 at 03:55
Yes I meant Lever. I took the screw out and it did not loosen the lever. – Adam H Nov 10 '20 at 04:41
