16
I have FiOS internet (200 Mbps up/down service), via an Ethernet cable entering my house from one of their ONT boxes outside. I would love to have it available at each of the wall plates in my house. When the Verizon tech did the install, he looked behind one of the wall plates and said "your house is wired for CAT5 but I don't know where the access point is," and just plugged the cable into a router in the back of the house.
I've since done some investigating, checking behind each wall plate. First, I think he's wrong about the CAT5: every non-coax cable is stamped CAT3, though some have 2 pairs of wires and some have 4 pairs. Second, I also can't find non-coax splitters in any obvious locations, including behind the wall plates, in the outlet boxes. Here's what's behind each wall plate:
  • Basement: Two 2-pair CAT3, two coax connected to a 2-way splitter
  • Living room: One 2-pair CAT3, one 4-pair CAT3, two coax (the previous homeowner had a router that was previously connected to one of these coax cables). Pictured, in case helpful: loose wires coming out of a wall
  • Bedroom 1: Two 4-pair CAT3, two coax
  • Bedroom 2: One 4-pair CAT3, one coax
So my questions are:
  • Can I use these cables for internet?
  • If so, how would I hook it up? Where is the splitter?
It would be great to have the outlets providing internet, though I gather that CAT3 is slow. A reduction in speed wouldn't be terrible, if it's more reliable than getting wireless across the house, and has low latency for video conferencing.
TylerH
  • 1,010
Mr. W.
  • 289
    Not an answer to your question, but since the house is already wired up, if you know where both ends of every wire are, you might be able to use the existing CAT3 to pull some CAT6 or other through the same paths just by tying them end-to-end. A nice duct-tape wrap might be the best way to make the join slim enough to fit through most gaps. Easier if you have access to the space above the ceilings (or below the floor in some cases) to pull it through. – Darrel Hoffman Dec 15 '20 at 20:39
    Where do you plan to hook up the 28.8 baud dial up modem? ;) – Stian Dec 17 '20 at 12:40
    This days CAT3 used for wired telephone. Also it has 3 pair wires, CAT5 is four. Using the old cable to pull new one mostly impossible. Wires run free in wall space and may be fastened somewhere to studs. Also it usually not straight run. My opinion for best solution is Ethernet over Power line. – user263983 Dec 17 '20 at 15:37
7 Answers7
28
A Definite Maybe...
Harper's answer gives a good overview of the general setup of a wired home network. There are two separate issues in your particular case that complicate things:
CAT 3
CAT 3 is nominally rated for 10 Mbps. It may be able to handle 100 Mbps. But it is not officially designed for that, and there are actual differences between CAT 3, CAT 5, CAT 5e, CAT 6, etc. that make the newer cable types able to handle higher speeds. Forget Gigabit networking on CAT 3, but the vast majority of home users simply don't need that unless they are doing true networking between their computers - for myself the only time I truly need it is when I am replacing a computer and need to transfer everything over the wire (and there are ways around that too)).
The big catch is that if you hook things up with CAT 3 and it can't handle the desired 100 Mbps then there are two possible things that could happen:
  • Downgrade to 10 Mbps - This is actually fine for a lot of uses. May not work well for 4K video, but probably work fine for most other things. That's still 6x the speed of standard DSL of just a few years ago, and is for each device in the network, not shared like a DSL connection.
  • Errors. Lots and lots of errors. Get an error once every minute and it is no big deal. Get errors every other packet and it is a different story. A lot of things will go into this calculation, but mostly dependent on the quality of the cable (CAT 3 is all the same, but how good are the connections, the network cards, switches, etc.)
A switch that lets you force 10 Mbps. can solve the problem, but your typical cheap unmanaged switches these days don't have that capability. Many network cards have that capability, if you know where to find it.
Wiring Topology
Twisted-pair Ethernet is based on a hub/spoke topology. A bunch of devices connect to a central location - hub or switch (these days, almost always a switch). If your house is set up for that then each of those CAT 3 cables has the other end in one location - typically in the basement, but could be anywhere.
However, plain old telephone service (POTS) is often installed daisy-chained to save on cabling costs. You might have one cable going to bedroom 1 with another cable connected to that one (call it a splitter or whatever you want) and from there to bedroom 2. While POTS doesn't need even CAT 3, it was quite common 25 - 30 years ago to simply use CAT 3 for everything (why stock two cable types) and a little later to use CAT 3 (especially if you had a few boxes lying around) for POTS and CAT 5 for networking.
Since you have some rooms with 2 cables in each location and some with 1 cable in each location, that indicates a real possibility of daisy-chained cables.
  • Oooh, this makes a lot of sense. I definitely see daisy-chained wiring on some jacks... So there's probably nothing to do, then, short of re-wiring the house? – Mr. W. Dec 15 '20 at 04:42
  • Not necessarily. You need to find what "other ends" you can. If you have only one chain through the whole house then it may not be worth doing much with it. If it turns out to be 2 or 3 then it may be enough to be worth working with, despite being only CAT 3. There are a lot of variations and permutations possible. A lot also depends on how hard it is to run new cables, which varies a **lot** depending on construction, particularly how hard it is to get between floors. – manassehkatz-Moving 2 Codidact Dec 15 '20 at 04:45
    cheap unmanaged switches won't allow forcing the port speed, but home routers have management, so some just _might_ allow doing that for the cheap switch included in them, given that some support VLANs, too. But, probably not a feature to be advertised, so good luck finding a fitting device. – ilkkachu Dec 15 '20 at 13:15
    OT for this stackexchange, but, there's actually no practical difference between _"getting errors above 10mbps"_ and _"downgrading to 10mbps"_. In both cases, the excess/erroneous packets will be dropped, and the protocol will automatically scale back the send rate. That's one of the major reasons TCP/IP have been flexible enough to last 40+ years. – BlueRaja - Danny Pflughoeft Dec 15 '20 at 13:44
  • @ilkkachu: some NIC drivers will let you force a speed, e.g. Linux `ethtool -s eth0 speed 10 autoneg off`. Or set the mask of which speeds to advertize when autonegotiating. – Peter Cordes Dec 15 '20 at 14:51
    @BlueRaja-DannyPflughoeft Unfortunately, I have found in practice that this does not always work the way it should, particularly in the 100 -> 10 mode. At least one time I've had to dig up a 10 Meg. switch just to be able to force things to make something old work with something new. – manassehkatz-Moving 2 Codidact Dec 15 '20 at 14:59
    "*May not work well for 4K video,*" There is no 'may' about it; 10mbps isn't even enough to handle 1080p streaming well, let alone twice that resolution. – TylerH Dec 15 '20 at 16:35
    @BlueRaja-DannyPflughoeft Both will be slow, but you may find that errors cause your actual effective speed to go way down (to like 0.1Mbps) – user253751 Dec 15 '20 at 17:10
    @BlueRaja-DannyPflughoeft, well, if the cable works okay as a 10 Mb/s link, but gives errors at 100 Mb/s, negotiating the link as 100 Mb/s but sending only 10 Mb/s worth of data would still be likely to get errors, since the packets would be sent on the wire using the faster encoding, even if there's less of them. (Also, as far as I remember, TCP isn't really made to deal with random errors, just congestion, but I might just remember wrong.) – ilkkachu Dec 15 '20 at 18:09
    I worked in a school in 1999 that was wired cat3. We put new-fangled 100Mbit PCI NICs on it and they definitely worked, but there were weird results, like one computer that always took 5x as long to copy the same file, and others that were randomly slow. We only had 100 Mbit hubs and one unmanaged switch, so no stats. The OS showed retransmits, such that 100 Mbit sending the same thing 5x to get a response is really only getting 20 Mbit. In no way will OP get gigabit over cat3, time for some ceiling crawling to check if the wire is loose. Cat6 would be ideal here. – Criggie Dec 15 '20 at 18:44
    Downgrading to 10Mbps seems insane. OP has a 200Mbps service and it's 2020. 10Mbps is painfully slow, and it's not like bandwidth requirements are going down. OP is going to want to pull that cable out sooner rather than later and do this properly. – J... Dec 15 '20 at 19:07
    "*6x the speed of standard DSL of just a few years ago*" how long since you had ADSL1 service? My country has notoriously shitty internet and ADSL2+ has been standard since 2006. – Coxy Dec 16 '20 at 03:47
  • DSL in many places in the US hasn't gotten much past the 1.5 Mbps that it started with many years ago. The telcos largely switched to fiber but in places where they can't economically ("middle of nowhere" == Starlink country!) or won't due to bureaucracy (my office, fiber literally running past my building) switch users to fiber, sometimes it is still 1.5, sometimes 3 or even up to 8. Or promise 8 and deliver 1.5. – manassehkatz-Moving 2 Codidact Dec 16 '20 at 04:19
  • @BlueRaja-DannyPflughoeft sorry but that is wrong. When TCP detects packet loss it will reduce the number of packets sent, but reducing the number of packets sent over a bad cable will not reduce the error rate. To reduce the error rate you need to reduce the actual transmission speed. Modern DSL variants are designed to adapt their transmission rates to the characteristics of the line. Ethernet is not, standard Ethernet negotiation depends only on the characteristics of the devices at the end of the link. – Peter Green Dec 17 '20 at 06:06
    Some Ethernet devices will try again at slower speeds if a link fails to come up, but that is a vendor extension and won't solve the problem where a link comes up but works really badly. – Peter Green Dec 17 '20 at 06:07
    This was on the money—the house was daisy-chained. Also, the short run of CAT3 in the house that I'm using works great (see above). Thanks! – Mr. W. Dec 20 '20 at 20:07
    One thing I noticed is that both 1Gbit and 2.5Gbit Ethernet are designed to reuse existing Cat5 cable plants. Even the difference between Cat5 and Cat5e are quite minor. – Yuhong Bao Feb 03 '22 at 01:12
14
I'm surprised no-one mentioned MoCA (http://www.mocalliance.org/) Depending upon the need for his coax cabling, he might be able to re-purpose it for network usage.
Also, Not nearly all routers provide PoE, if it's needed, the OP will want to ensure the router or switch he gets provides it. If not there are PoE injectors that can take it's place.
George Anderson
  • 23,066
  • 35
  • 79
  • We use this with FiOS and it works fine for us. Since the previous owner of the OP's house already had a router connected to the coax it shouldn't require any wiring changes. – user3067860 Dec 15 '20 at 14:33
    This is the only acceptable answer. The CAT3 is trash and will be a pain to deal with, with any modern router. The auto-neogtiation and error detection and drops will drive someone nuts. – DMoore Dec 15 '20 at 18:39
  • I used MoCA for a few years and it was largely fine until - I think - our coax failed. – William Dec 16 '20 at 17:55
  • If each room has a dedicated line to the basement, passive ethernet extenders over coax are cheap and will work, but generally peak at 100mbs – rtaft Dec 16 '20 at 18:07
  • Thanks—this was critical (see above), and I had not heard of it before your answer! – Mr. W. Dec 20 '20 at 20:06
Ethernet splitters are powered.
Ethernet uses powered splitters called "Hubs", at their most basic. But they are largely deprecated for Switches, which wire up like hubs, but give each port its own "nano-network" and does packet switching, so every packet only goes out to the ports it needs to, reducing congestion. Because it gives each port its own physical network, a switch can run each port at a different speed to suit the other end. A "router" is a switch with ability to do "NAT", firewall, network splitting (guest network etc.) and a bridge to WiFi, all in one box.
All of them need electricity... but there's a thing called PoE (Power Over Ethernet) that can help by getting power to places it isn't. (not much power, but enough to run a router/switch). Only some routers and switches support PoE, and far fewer support PoE as a means to power themselves.
Ethernet can work on Cat 3 cable
If possible you punch down all 8 wires, but if the cable only has 4 wires, you can get by with wires 1, 2, 3 and 6. You have to put the wires in the right places.
Ethernet has 4 versions: 10 megabit, 100 Mbit, 1000 Mbit and 10,000 Mbit. Cat 3 will limit your speed to 100 Mbit if you are lucky. (having only wires 1,2,3,6 would limit you to 100Mbit even if you had Cat6). I worked for a company that invented 100BaseT. I'm not sure our standard won, but ours worked on Cat3.
Your 200 Mbit FiOS connection is insane overkill for normal internet use. Even 4K video needs only 15 Mbit. Honestly even at 10 Mbit, the Internet will be totally usable - the major bandwidth hog is streaming video, and that'll work, just not at 4K.
I wouldn't lose any sleep over it, but obviously if you're swerving out of your way to get 200 Mbit FIOS, you must have a reason to need so much bandwidth. You'll have to see if you can get away with 100 Mbit on your Cat3, or fish new wires.
Hook the wires to punchdown blocks. Put them in faceplates.
https://www.youtube.com/watch?v=0gxNZoPcnP4
Back at your hub location, they make blocks which have a number of Ethernet sockets in a row. Punch all your ethernet cables down to those, then use jumper cables to connect from the punch-down block into the router or switch. There are plenty of pages and videos on how to do that.
  • It is funny how Comcast/Xfinity and Verizon in my area (I am sure it is similar in many other places of Cable TV vs. Telco) keep going at each other about higher speeds for all your devices (a joke - as you noted, even 4K needs 15 Mbit, and Zoom (for example) only needs typically 3 - 4 Mbit) and "best WiFi" (when in reality the single-router/switch/WiFi from the big companies is rarely the "best"). Your answer is, as usual, right on the money, but one possible exception here which I'll write up as a separate answer. – manassehkatz-Moving 2 Codidact Dec 15 '20 at 04:19
  • This is great, thanks! But, and this sounds so dumb, where are the wires going? Where is the other end of the cabling coming out of, say, the living room outlet? How do I figure that out? – Mr. W. Dec 15 '20 at 04:39
  • In theory, you can tone out the wires. In reality, that works well when you have a bunch of cables in one place and have to identify one of them, but it doesn't work so well when the wire could be "anywhere". – manassehkatz-Moving 2 Codidact Dec 15 '20 at 04:49
    @manassehkatz-Moving2Codidact the toner will work for figuring out where _this_ wire ends up, even if you have to run around to every room in the house to find the other end. Not as convenient as IDing "this" wire in the bundle in the network closet, but it's the same principle, you just get more steps in. ;) – FreeMan Dec 15 '20 at 12:17
    _"a switch will negotiate the fastest speed the wire can handle"_ -- will it, actually? I had the understanding that Ethernet devices will just negotiate the best common speed the _devices_ can work with. It's been a while since I've faced cable issues like this, but I do recall at least hearing about a case where the devices negotiated a gigabit link over a two-pair cable, which obviously didn't work to actually transmit anything. – ilkkachu Dec 15 '20 at 13:39
  • There are also 2.5 and 5Gbps standards which still work over Cat5e / Cat6, which is part of the motivation for connecting WiFi APs (https://www.electronicdesign.com/technologies/wireless/article/21801057/justifying-25g5g-ethernet) . Also useful for home / consumer as a budget alternative to 10G ethernet which has remained pretty pricey for many years - 2.5 and 5G NICs are cheaper, and IIRC switches are significantly cheaper than 10G. https://en.wikipedia.org/wiki/2.5GBASE-T_and_5GBASE-T – Peter Cordes Dec 15 '20 at 14:56
    @ilkkachu There are some switches that will automatically detect what the cable can handle, but it's not standard. – user253751 Dec 15 '20 at 17:10
    With the amount of troubleshooting you are going to be putting the OP through they could have ran all new cables and patched up the drywall. Running CAT3 on a new PoE switch is a mess and I have had to troubleshoot this (for illogical issues) at client sites. There are a LOT of rules and gotchas for the auto-negotiation process to work and pick the highest speed. Your answer is turning into a very complicated shopping questions. I would not go this route if I were the home owner - at all... Theory does not equal reality. – DMoore Dec 15 '20 at 18:46
  • Technically speaking, a switch is not a hub. Both are types of _bridge_. – chrylis -cautiouslyoptimistic- Dec 16 '20 at 02:30
  • I would drop all mention of hubs... they have been quite rare since about 2000 (largely because, relevant to this question, hubs *aren't* compatible with auto-negotiation, so they went out of fashion when 100Mbit/s started getting significant traction). Switches aren't hubs, they're switches. – hobbs Dec 16 '20 at 03:13
    @J... I took that out. – Harper - Reinstate Monica Dec 16 '20 at 04:22
  • @chrylis fixed that. I worked for Kalpana, I knew that, just oversimplified :) – Harper - Reinstate Monica Dec 16 '20 at 04:25
  • @ilkkachu Yes, the gigabit-over-two-pairs thing is fairly usual, because the whole autonegotiation procedure runs only over two pairs. It will thus inevitably end up negotiating GE and then the link will fail to come up due to the missing pairs. Most devices (except for the very dumbest ones) can recover from this by disabling GE and renegotiating. However, that may take multiple seconds, so in my experience, running over two pairs is the #1 reason to disable autonegotiation. – TooTea Dec 17 '20 at 09:33
  • @chrylis-cautiouslyoptimistic-: FWIW - a hub is not a bridge. – psmears Dec 17 '20 at 10:11
  • @TooTea yeah, but do they negotiate on pairs 1-2 and 3-6? Because those are present in 4-wire cables. Makes more sense to negotiate on 4-5 and 7-8, since that effectively tests whether they are present. – Harper - Reinstate Monica Dec 17 '20 at 17:34
  • @ilkkachu Yeah I got rid of that. – Harper - Reinstate Monica Dec 17 '20 at 17:58
  • @Harper-ReinstateMonica The autonegotiation mechanism is shared with Fast Ethernet (100Base-TX), so it runs only over the two pairs used by both implementations. It has to be like this, otherwise it wouldn't work with a FE device talking to a GE device. FE devices often don't even have the pins in the connector for the two unused pairs. Done like this, autonegotiation works for any combination of 10Base-T/100Base-TX/1000Base-T devices. No need to have a special protocol to test for missing pairs between 2 GE devices, that's handled by "we negotiated GE but the link doesn't want to come up". – TooTea Dec 17 '20 at 20:16
If you do not want to get involved in a huge project of rewiring ethernet, your best bet is figuring out the optimal locations in the house for a couple of wifi transmitters and setting them up in a WDS network. One location will be reachable to the ONT and the other location will be as far away from that as you can get. You can use ethernet-over-powerline adapters to connect to the remote wifi which work quite well in a residential setting and are 100Mbt.
I setup 3 transmitters in our vacation house for ideal coverage. I did run ethernet to 2 of them using existing phone lines which were fortunately not stapled where they passed through floors so I used the trick of pulling the new cable through using the old cable. The 3rd is next to the cable modem.
Pulling ethernet cable is not as hard as it's made out to be.
Ted Mittelstaedt
  • 1,777
    WIFI doesn't always work all that well for streaming video. When my wife got her ROKU it was initially setup for WIFI. Direct line of sight between the WIFI router and the ROKU box. It was slow, hung a lot, crashed. She set it up and I asked her why didn't you just plug it into the ethernet port behind the TV ? So I did that and it started working perfectly. BTW, here's your funny for the day: " what is Ethernet used for? Answer: To catch the etherbunny. Sorry, couldn't resist! Take care and stay safe. – George Anderson Dec 15 '20 at 17:47
  • @GeorgeAnderson that's not normal. Performance that bad is the result of either an extremely bad RFI environment, an absolute trash WiFi AP, or some just plain broken hardware. – hobbs Dec 16 '20 at 03:16
    I have seen incompatibilities in different brands of wifi chips talking to each other many times before. In fact I carry about 10 wifi routers in my car and when I have a customer with a problem like yours I will start swapping routers out until the wifi problem goes away. The customers "bad" router then goes into my router bag and quite often months later it ends up replacing someone else's problem wifi access point and theirs goes into the bag. But in any case the wifi chip in the Roku is garbage my father got one of those and I had to do the same thing as you did. – Ted Mittelstaedt Dec 16 '20 at 11:50
  • @TedMittelstaedt Thanks for the confirmation, you are obviously a professional in the field and I'm not. Also, the WIFI worked fine for everything else, just the ROKU was crapping out. 15 years ago when I built my new home, everybody was saying, don't bother with internet wiring, everything is going wireless anyway. Well, I ignored that advice and have a pretty decent setup with cat5 in nearly every room. Glad I did. Faster and more secure. – George Anderson Dec 16 '20 at 13:54
  • @GeorgeAnderson I just broke out an old Roku3 that had been on the shelf for 8 months... it would crash and crash and crash... was giving it up for dead, but thought "why not" and explored settings and found "manual update". It said "Last updated Dec 10", it was in a box then, so maybe it meant Dec 10 2016 lol. Anyway that cleared it right up. – Harper - Reinstate Monica Dec 17 '20 at 17:39
As @manassehkatz-Moving 2 Codidact said, you can theoretically use Cat 3 for 10 Base T. The problem is that finding 10 Base T adapters (and such) is difficult at best.
There is also an officially approved 100 Base-T4 standard for doing 100 Mbps over Cat 3 wire. Unfortunately, it's probably even more difficult to find 100 Base T4 adapters than 10 Base T adapters.
I wouldn't consider either of those particularly practical.
There are a couple of others that seem more practical to me. One is MoCA, which has already been mentioned. I haven't tried this, but if the building is wired for television cable, it apparently works pretty nicely.
The other would be network over your power cabling. This uses your electrical wiring to also carry network signals. I use this in my house, and it works pretty well for me. You can get these in a variety of speeds up to around 1.2 gigabits per second, but slower versions are a bit less expensive. The biggest problem I see here is lack of standardization, so one vendor's parts don't necessarily work with another vendor's. In some cases, you can't even mix different speeds of adapters from the same vendor (but I believe most vendors do at least maintain backward compatibility with their own older designs).
    There is also an officially approved 100 Base-T4 standard for doing 100 Mbps over Cat 3 wire True, but this would need a ethernet jack that supports this protocol at each end, (Ive never seen adapter or switch for this) and would require 4 wire pairs, and some of his wires only have 2 paire – camelccc Dec 15 '20 at 20:47
  • @camelccc Actually, there's also the 100Base-T2 standard, running over just two pairs of Cat 3 (using almost the same advanced technology that powers 1000Base-T). However, the hardware for that is nowadays likely just as easy to come by as -T4 hardware (as in, you have to build it yourself). – TooTea Dec 17 '20 at 21:15
Id point out that with coax, when installing 10Mbit thin coax there were no spliters, the coax typically daisy chained around every device, in a single collision domain. the length limits on branches are extremely short, less than an inch in the branch of the T going into the card if I remember.
There are modern coax ethernet protocols that may work if the topology is correct, but if the topology is a daisy chain on the coax as would have been the case installing 10Mbit thin coax ethernet, this is probably useless.
Id frankly at least try running the ethernet over the cat3 and see what happens. Most network devices will get the best they can out of the cable dropping the speed if the error rate is too high. It will probably work - it wouldn't surprise me if it connects at gigabit. Yes it may be out of spec, and the length runs may be longer than 100M allows, but the length doesn't always matter much if you use all switches with no hubs. I can't remember the last time I saw a hub. If the UTP was ever intended for ethernet it is almost certainly a star config, which is what you want
camelccc
  • 111
Migrating OP's solution/response from their question to an answer:
I took a little bit from column A, and a little bit from column B.
I got a cheap tone and probe kit to confirm that the coax and CAT3 daisy-chained through the whole house. And I'm using two MoCA bridges to convert the FiOS signal from Ethernet to coaxial, snaking through the house and converting back into a Wi-Fi router. Ethernet out from the router goes back into the wall, traveling upstairs via a short run of CAT3 in the wall. From my office upstairs, if I plug my computer into the wall jack, I get 100Mbps up/down with 7ms latency, which is exactly what I got from plugging my computer directly into the FiOS ONT.
I now get great speeds when plugged in, and feel good knowing that I'm taking advantage of the wiring in the house. (Most of it anyway—I am cutting the daisy chain short by one link.) Also, the Wi-Fi router is much more centrally positioned, so I get better wireless speeds too.
I am using MoCA, and also giving CAT3 a shot based on your recommendations. It seems to be working great so far.
Here's how everything's hooked up:
final house wiring diagram
- Mr. W.
  Dec 20, 2020 at 20:02
TylerH
  • 1,010
