I have some exterior concrete stairs that were finished poorly. The treads are back-sloped and pools sit consistently on the treads in the fall/winter.
I am having the tread surfaces ground down so the water can drain. The exposed smooth aggregate surface now becomes a slip hazard instead of the ice that would have formed in the puddles.
What product would work to coat concrete in an exterior application that would hold up over time? or is there something else I could do to make the concrete surface non-slick once it has been ground down?
I suppose I could look at installing metal or rubber grip strips. Ideas?
Fresh Codemonger
  • 13,439
Non-slip paint/sealers frequently used for this kind of thing. I usually see a coat applied, grit scattered onto the wet paint, then a second coat applied to hold everything.
It appears that single-part solutions exist too.
Grind them a bit further and then put down thin slices of brick (or rock or floor tile or whatever you want) on mortar right on top of the concrete. Paint is never a good idea on concrete it always peels off. (and yes I know there's a group out there that luvvs painted concrete and will come out screaming)
Ted Mittelstaedt
  • 1,777
Grip tape.
grip tape
https://www.homedepot.com/p/4-in-x-34-ft-Anti-Slip-High-Traction-Safety-Grip-Tape-for-Stairs-Steps-Ladder-MA-ASGT-4-34/312387533?NCNI-5
You can see it is tape on one side and sand embedded in matrix on the other. We had some of this on the front porch for years. It is cheap and quick. I imagine like any other solution of this sort durability will have to do with how much sunlight strikes the tape on a daily basis. A nice thing too is you can see if it is wearing out, and replace it.
Willk
  • 6,593
  • I am going to settle on this answer. The concrete after grinding is surprisingly non-slip. I'll see how it goes once algae has a chance to grow and if so I'll give the grip tape a try. After 2 guys for 2 days = 28 man hours grinding I am not keen to throw more time/money at this. – Fresh Codemonger Dec 17 '20 at 07:20
