36
We're trying to track the origin of a very putrid smell in our condominium. We have a loft type home, which means two floors with a drywall ceiling between the first and second floor.
I first noticed a subtle odor in the kitchen, which is not an uncommon place to notice subtle odors. I checked the usual suspects:
  • Something in the bottom of the trash bin
  • Something rotting away behind an appliance
  • Something putrid stuck in the sink trap
  • Something rotting away in a cupboard
While we are guilty of all of the above and have removed the offending artifacts, the odor persists weeks later and grows in intensity. I realized that the odor seems the strongest from the stock room built under our stairway directly facing and adjacent to our kitchen, in which all ceiling joists for the downstairs level arrive unfinished.
I cleaned out the stockroom, expecting to find the remains of a mouse, but to my dismay there was only one partially dead insect that I quickly dispatched. The odor seems to be emanating from something existentially challenged somewhere in our ceiling.
I've done the following:
  • 'sniff tested' the end of each joist where I can get access to do so. The smell seems to be coming from everywhere.
  • Used a flashlight to peer as far down each joist to joist channel as possible, I can't see anything that could be causing this.
  • Removed and replaced some lighting fixtures in in order to get a better view of what might be in the neighborhood
  • Sent a fish tape through every opening I can find hoping to reel in, or at least determine the location of the cause
  • Duct taped every opening between joists in the pantry area. One by one, eventually all.
The smell keeps getting worse.
What, beyond cutting holes in the ceiling all over my first floor can I do to pinpoint the source of this annoyance? Is there some sort of chemical test or something else I can get to narrow down the location and unfortunate source of this smell?
aparente001
  • 773
Tim Post
  • 1,664
  • See also: [How can I find the source of a mysterious bad smell](http://diy.stackexchange.com/questions/8453/how-can-i-find-the-source-of-a-mysterious-bad-smell?rq=1) – BMitch Dec 05 '12 at 17:20
  • @BMitch Alas, I tried that and even smelled a mop in the name of finding this. The mop has its own issues, but this isn't one of them. – Tim Post Dec 05 '12 at 17:24
  • This happened to someone I know a few months back. He got something (maybe enzyme-based, I'm not sure) from his pest control guy where you drill holes in the walls, spray this stuff into the cavity, then patch/paint over the holes and a short time later, no more smell. I'll talk to him later today and see if he can remember what he used. – Niall C. Dec 05 '12 at 17:24
  • @NiallC. I'd really appreciate that, my last resort requires a lot of drywall patching which I'm not particularly good at doing. – Tim Post Dec 05 '12 at 17:26
  • are you getting flies? – The Evil Greebo Dec 05 '12 at 17:32
    Call the mob? see if they're missing anyone? Sorry, I read the title and assumed Goodfellas. – Rich Homolka Dec 05 '12 at 17:34
  • @TheEvilGreebo No, surprisingly no fly activity, I was hoping to see flies fly _out_ of the joist cavity by now. – Tim Post Dec 05 '12 at 17:36
  • Condominium right? So it may not even be in your walls. – The Evil Greebo Dec 05 '12 at 17:41
  • @TheEvilGreebo The construction (even partition walls) are block and mortar, structurally each condo is isolated by a formed concrete wall. I don't think this is coming from my neighbors. – Tim Post Dec 05 '12 at 18:05
  • You'd be surprised at how much air flow you can get between units. – The Evil Greebo Dec 05 '12 at 18:10
  • Always remember my pirate motto, "Dead men tell no lies" At least your smelly ceiling will not lie to you. Good luck. – shirlock homes Dec 05 '12 at 22:07
    If there is any moisture left in the corpse, a very good IR sensor may pick it up. – shirlock homes Dec 05 '12 at 22:08
  • Just tough it out. Whatever it is will eventually decay to the point where the stench is bearably minimal. – oscilatingcretin Dec 15 '12 at 02:04
    @TimPost Sorry for the delay in getting back to you on this (my friend couldn't remember where he'd left the bottle). The stuff he used is a drain-cleaner called [BIO-GEL](http://www.pestwest.com/us/bio-gel.php). Hopefully your smell is completely gone by now and you don't even need this information. :) – Niall C. Jan 14 '13 at 18:03
  • @NiallC. Fortunately it finally faded away, but that's definitely going to come in handy for someone else. I didn't realize it was such a common problem. – Tim Post Jan 15 '13 at 09:22
  • Recruit some ants for the search. – MoonMind Oct 14 '15 at 10:59
Oi! this reminds me of an experience I had about seven years ago. Horrible smell with no obvious source. Turned out that the cats had killed a rat and hidden it behind the books on the bookshelf. Only noticed it because of an awesome slimy trail of maggots.
Anecdote aside, my recommendation with this particular occurrence is to wait it out: rodents tend to decompose in a relatively short period of time, and the smell will dissipate within another week. If it persists you're dealing with a larger animal - say a full grown opossum or bigger - which leads to the really pertinent issue: how did the offending critter get to where it got before it died?
As a self-respecting homeowner you should do whatever you can to prevent entry by pests into your home. Sometimes this involves a thorough investigation by a professional but for the most part an observant individual can determine likely points of entry and fix them.
Most modern houses are covered by siding/doors/windows in every location with three major exceptions: foundation line, crawlspace venting, and eaves. All apertures can be sealed with some combination of welded wire, steel wool (coarse) and possibly adhesive by a determined homeowner. The more aesthetically pleasing approaches are less simple and more costly, but there are lots of solutions out there.
As far as your storeroom goes - I recommend rocking->taping->mudding to close any access points for the critters, same with any unfinished space that is prone to pest invasion.
Hope you have a better olfactory experience in the near future!
Paul
  • 842
    That's .. pretty much what I did, just sealed up all possible places I could find where the stench could be escaping. The smell is all but gone now. This is the correct answer in this case, if you don't want to bust up walls and ceilings, you better be prepared to wait it out. Several exterminators tried to find it, none could. – Tim Post Dec 17 '12 at 14:18
...And wear a full faced respirator and head lamp if and when you go into any confined space.
A bottle of Chlorox clean up spray will kill smells instantly.
