-1
Closet doors, particularly those for the closet section which houses a rail with hangers, often have a sort of a cylindrical bar attached to the inside of the door. A thin bar at a short distance from the door, but covering most of its width, on which you hang belts or ties.
My motivation is, as you might have guessed, having a closet which is missing this device and wanting to get one. Hopefully I won't have to settle for something like in the picture.
I was wondering whether this fixture has a name - a single noun or a phrase - that is commonly used.
(This is actually not such a great example, because what you're seeing here is an IKEA Grundtal bar intended for the kitchen.)
Alaska Man
  • 13,521
einpoklum
  • 2,657
  • 37
    It could be a number of things. For search terms try Tie rack, Belt rack, Closet organizing bar, Towel bar, belt organizing bar. You could make one out of pipe or a wood dowel. There are no rules for your closet, come up with something that works best for you. – Alaska Man Jan 01 '21 at 23:31
  • @AlaskaMan: I'm not well-enough tooled to make my own. But - I think this comment should be an answer. – einpoklum Jan 01 '21 at 23:45
  • Ok, it is an answer. – Alaska Man Jan 01 '21 at 23:50
For search terms try Tie rack, Belt rack, Towel bar, belt organizing bar.
There are no rules for your closet, come up with something that works best for you. It could be as simple as a piece of wood with some hooks screwed into it. (have the home center cut the wood to length, not tools needed except to screw it to the wall/closet door)
copper pipe towel rack
Alaska Man
  • 13,521
