A few years ago I installed a very small sub-panel for hot tub and one outlet. The panel is mounted on a stem wall outdoors about 1.5' off the ground. It only has 2 breakers in it: a 240volt for the hot tub and a 120v for an outlet for a outdoor lighting transformer. Both are GFCI protected. The hot tub is due for replacement so now would be a good time to update the sub-panel location if needed. I have some flexibility in the wiring and am thinking maybe I should mount it on a pressure treated post. There is a potential discrete location that would work near the hot tub location. Everything would be in appropriate conduit of course.
The reason I did that is I thought I needed a "local disconnect", I'm not sure if that was accurate, but I think it still is.
So my question is: "Is there a minimum height for a sub-panel?"
