I'm installing a mini-split system in my shop, but realize I’ll probably need to move the outdoor unit in 6-12 months. Does it make sense to try to add a pair of valves to each line to allow them to be detached without losing refrigerant? Is that even possible?
Asked
Active
Viewed 133 times
Do you have an hvac License? There are DIY systems that have self sealing valves that you can legally set up and move. A standard line set would require a pump down of the lines. So this is not really something you could do in most of the world that requires licensing to open a system. – Ed Beal Jan 08 '21 at 16:36
Right, I guess I’m asking if there’s a way to do this without having to let the refrigerant out. Do you have a link for these self-sealing line sets? All I’ve found is systems you can diy install (ie one time). – Rick Jan 09 '21 at 00:28
1Rick the self sealing valves are in diy type systems. They cost as much more than a service call because they are that they are very expensive to make. a section removable you would need 2 sets. The diy systems have a fixed line set length the extra is coiled up at the compressor. I don’t know of a source for them or if they are even field installable. At the + 400$ price tag of diy systems I only learned about them a year back as a training thing because DIY folks don’t have testers to verify leaks and leakage was the cause of failure. So I won’t be even trying them if I could find them. – Ed Beal Jan 09 '21 at 16:34
