This is the sort of wrench I have in mind:
In the Wikipedia article (Socket Wrench) displaying this image, it is described as a spark plug wrench, but there are wrenches of this style in many other sizes, and for many other purposes - anywhere one has no access from the side and a long bolt or stem preventing even deep 'conventional' sockets (having a square socket for a drive on the other end) reaching the nut.
The image itself is labeled "box spanner", but if I search for that at Home Depot, Harbor Freight, etc., I get back the type of wrench that has a closed, 12-point ring on the end of a handle, and if I search for "spark plug wrench", I get tools specifically for that purpose. I suspect that "box spanner" is British usage; is there a term in American usage that picks out just this style of wrench, regardless of its purpose?
Update: Thanks to everyone for your help and advice. As it happens, I was able to make a suitable tool by cutting six notches in the end of a steel pipe. While this was not as good as a real wrench, it was sufficient to grab the points of the nut and stop it from turning, in the manner of a basket strainer wrench (as suggeseted by Jimmy James.).
sdenham
  • 213
8 Answers8
This is a tubular wrench.
Apart from the British "box wrench" term, "tubular" is in my experience the most common generic name for these tools. You can get a full set of them (I have one, though in metric sizes).
It looks like googling "tubular box wrench" is the best way to get the right stuff while eliminating the American meaning of "box wrench".
TooTea
  • 2,313
  • Thanks - this combination of terms picks out this type of wrench specifically. It seems that my difficulty in finding them in the USA is that, except for the specific purposes already mentioned, they are not readily available. – sdenham Jan 14 '21 at 13:19
  • I think I have one or two. They came with plumbing fixtures, I think. – JimmyJames Jan 14 '21 at 19:49
    I'm struggling to imagine a use case where a socket set and extension wouldn't work and this would. I assumed these were just added to packages in case the purchaser didn't have real tools like those little flat stamped wrenches. – JimmyJames Jan 14 '21 at 19:55
    Never mind, I figured in out. A basket wrench might be an alternative though. – JimmyJames Jan 14 '21 at 20:02
  • @JimmyJames use case ... -> I have a large double ended one of these. It fits over the two standard size elements and thermostats used here (NZ) in hot water cylinders. It need to be large in dia to fit AND deep to accommodate the electrical fittings which extend from element and thermostat. A socket that did the job would be very heavy indeed and probably priced at $100 plus - unless it was made lightly as a custom solution for this job - and then you'd need two of them. – Russell McMahon Jan 15 '21 at 11:45
  • [Example](https://lh3.googleusercontent.com/proxy/8CrCwhZVT3e508Py05izDQcgc3pS2JN7p-1PNZEMApWFX9Ai5zPbFe4eB7Ywd2c93H_AURLqIAH8YwJ7awUpXufOeWTh91MEYbSQaOedj5wZPGVJvv1ERCaw4S2SXbHRPTGcRjEqQjHsj58WgJIQtWQ7l3ubNjiL) – Russell McMahon Jan 15 '21 at 11:45
  • @RussellMcMahon Like I wrote above, I figured it out. Just forgot why I needed these in the past. – JimmyJames Jan 15 '21 at 16:59
  • @JimmyJames Thanks for the suggestion - I made something resembling a basket wrench by cutting notches in a length of steel tubing. – sdenham Jan 30 '21 at 13:06
There are some that are made for removing and installing faucet valves.
Shower valve socket wrench.
Alaska Man
  • 13,521
That's another
Disposable Wrench
or possibly
Disposable Tube Wrench
Cheaply stamped out of metal tubing, they are sold with products for the single use of installing that product then discarding. You can find them often with furniture and fixtures.
  • I was just about to add this to my answer, but you've got it covered. I find that most of the one's I've got have come with something else for assembly of that thing. I do believe I may have received one with our last lawn mower for installing the spark plug, thus lending credibility to the OPs "spark plug wrench" findings. – FreeMan Jan 14 '21 at 11:42
  • @Feeman I had actually purchased a "spark plug wrench" to do maintenance on my motorcycle. – Aleks G Jan 14 '21 at 15:59
  • AKA, *garbage*, +1. So you should leave it behind in the base cabinet, or put it in the box of house parts. – Mazura Jan 15 '21 at 01:51
One set I found calls it a "Valve Socket Wrench".
No recommendation of brand or vendor implied or intended
  • I was going to add this as I have a set on a wire keeper also they may not work for a tough pipe at 1-1/4” – Ed Beal Jan 13 '21 at 21:33
These are also known as a box wrench.
Solar Mike
  • 26,234
  • 57
  • Unfortunately, searching for "box wrench" on Google, DuckDuckGo, Home Depot, Lowes and Harbor Freight gets the same result as I described for "box spanner". If you know of ayone selling these items as box wrenches or anything else, a link would be much appreciated! (maybe they are just not made anymore, except for spark plugs, shower valves and water heater elements?) – sdenham Jan 13 '21 at 22:32
That's a spark plug wrench. Mostly used on 2 and 4 cycle engines. Chainsaws and trimmers where the plug is recessed this type of wrench is necessary for maintenance.
ojait
  • 10,949
  • I had one exactly like the picture, in the tool kit that came with a 1967 Honda motorcycle There was also a rod to insert through the holes to apply torque. – Michael Harvey Jan 14 '21 at 07:32
Not directly related to your question, but you mention in the comments that there is limited side access and you will need a lot of force to be applied.
Be aware of things called "crows foot" wrenches. These are commonly used in HVAC and heavy equipment (hydraulic) maintenance. crows foot wrench
The wrench is a combination, made up of a "wrench part" and a standard ratcheting handle plus zero or more extension bars to provide depth offset. The wrench part looks like an open-ended wrench with a cut-off handle, where the stub of the handle has a square hole punched out for the ratchet handle to plug in.
For "flared fitting" work -- usually gas piping -- the open-ended wrench may actually have stubs on the ends of the arms, as shown in the photo. General-purpose crows-foot wrenches don't have these stubs, and just look like stubby open-end wrenches.
These wrenches do require a certain amount of space right next to the fitting or nut. But they allow offsetting the lever arm, and they allow using a torque wrench if you desire. As with any ratchet wrench, you can get a truly obscene amount of torque going with a "cheater bar" and a sacrificial helper to hold things steady.
aghast
  • 1,592
As a general term I would refer to these as "Tubular socket wrench"
ontrack
  • 101
