I just installed new floor in my bathroom. I'm getting ready to install the new toilet, but I think I might have got some bad advice on how to handle the flange.
Currently I have a metal/PVC flange that's slightly bent in the back, but otherwise okay. I did not floor under the flange per the advice I received, so the flange is just floating. The top of the flange is between 1/4" and 1/2" above the finished floor. The flange looks like it would rest on the finished floor had I installed floor under it. It looks like the existing flange is glued to the outside the pipe.
Do I need to remove the flange? I think I could just shim under it to support it, but there isn't a lot of room. I could replace the flange, but that's a whole thing, and I'd still need to shim it since the floor doesn't come under the existing flange.
How would you recommend I solve this problem?
The bolt holes are 180 or directly across from each other you will notice the flange can be turned (at least when new) always use brass hardware.
Steel will corrode and I have seen people break expensive toilets trying to get rusted bolts out. The light weight flange is strong enough to keep the PVC pipe in line with the toilet.
Old cast rings were thick and when replaced the new part goes inside the pipe and has some movement to align with the toilet (the style I use).
So as I have tried to convey, the flange is to hold the pipe securely to the toilet thus preventing a leak. The wax seal, seals to the toilet primarily and a bit squishes out to the flange but enough to block sewer gas. The flange is for anchoring the seal not the seal itself. If exposed to urine water these cheap flanges would not last very long at all. I have seen cases where a flange was two low because of tile added. The old cast flange was still there but they used 2 wax rings to get it to seal and it worked for many years from what I could tell. The avocado tile was a 70’s thing.
So I would not worry about a small dent just pre set the toilet and make sure the screw holes line up, squish the seal into the toilet but at the edges of the wax leave the center high, wipe the pipe and set the toilet snug the screws don’t over tighten or the toilet could crack and you're done.
  • "*don’t over tighten or the toilet could crack and your*" **SOL**. With the flange that high you may need to use a thin wax ring or explore some of the new wax-less options. If your toilet does not sit flat or rocks they make toilet wedges to address that issue *if it is not significant*. https://diy.stackexchange.com/questions/2233/what-do-i-do-about-a-toilet-flange-that-is-too-high – Alaska Man Jan 14 '21 at 20:48
Just wanted to clear up some points regarding flange orientation:
-In the United States (California) the reason to have the flange so that it's not in a recess is to prevent "concealed fouling".
-Further, the toilet flange is not meant to provide structural support the toilet. The flange should be installed firmly to the floor with corrosion resistant screws
The toilet flange should be above the finished floor and supported from the underside. It appears it is above the finished floor ,but not supported.
The best way to support the flange is to make up a small batch of floor leveler and pour it into the floor depression until its level with the existing floor.
ojait
  • 10,949
  • There may be, probably is, a gap of some size between sub-floor and pipe. – Alaska Man Jan 14 '21 at 21:40
    Flanges provide anchoring _upward_. I seen no reason to support it from below. If anything, I'd add screws anchoring the flange _down_. – isherwood Jan 14 '21 at 21:51
    Also, you do not want to fill the void where the flange bolt needs to be inserted. – Alaska Man Jan 14 '21 at 21:53
  • I'm positive any plumbers in the audience will confirm all of my statements. – ojait Jan 15 '21 at 01:02
  • If the flange is above the finished floor than floating the recess won't effect the placement of the bolts. The bolt opening is above the floor. – ojait Jan 15 '21 at 01:03
    Not supporting the flange underneath will stress the waste pipe from the toilet and persons additional weight – ojait Jan 15 '21 at 01:05
  • @isherwood thanks for the comment, what do you mean by "flanges provide anchoring upward?" –  Jan 15 '21 at 10:43
  • @ojait thanks for the answer, your last comment about stressing the waste pipe was my original concern. –  Jan 15 '21 at 10:46
  • It's a fair point, but I can't see a wax ring putting undue force on a 3" pipe assembly. If anything, the concern would be movement in general. Again, I'd screw it _down_ unless it's really difficult to move. – isherwood Jan 15 '21 at 13:50
  • where i'm from code states the flange must be secured to the floor. – ojait Jan 15 '21 at 14:04
