I’m having serious issues replacing an antique faucet stem on old old claw foot tub.
The hot water nozzle slowly leaks and I can’t find a replacement stem or even a washer that would fit. I emailed Faucet Parts Plus and they replied we have nothing that matches. Does anyone have any suggestions?
The picture is the cold water cartridge which is the one that works. I need a hot water cartridge/stem. (It looks as though it was cobbled together with a different washer to slow the leak) 12 spline.
Cartridge and washer
Chenmunka
  • 1,296
  • I would recommend taking it to a local plumbing supply house (_not_ a big-box, home improvement store). The odds are good that they'll be able to find you a part that will work. They may have to order it, but they're the ones with experience and calipers to take all the required measurements. – FreeMan Jan 19 '21 at 14:24
Most hardware stores will be able to find a match. Bring the stem with you. There are usually many replacements in stock. If not the usually have a plumbing parts book or software they can look up the specifications and then special order it for you. It may be helpful to take a picture of the faucet if they want more information.
ojait
  • 10,949
