I moved into a newly remodeled home. The walk-in shower walls are grouted. Now the corners have started to crack.
How do I slow down the cracking? Should it be caulked, or would that be a bad idea?
mac
  • 2,571
chrisjlee
  • 281
The corners of the shower walls should never have been grouted in the first place. Corners are the most subject to movement and thus the most likely to crack, so they get caulked, not grouted.
The Evil Greebo
  • 25,821
  • 124
    I like to use a colored sanded caulk in this situaiton. It looks very similar to grout. Sanded caulk comes in various colors. You should be able to get a close match to the grout. – RSMoser Dec 12 '12 at 17:46
    Oh one other thing would it be a bad idea to caulk on to of the grout? – chrisjlee Dec 13 '12 at 16:50
  • As opposed to removing it? The grout is likely to crack further, and if you caulk over top of it, the caulk on top of the cracking grout could be affected by the cracking. Better, IMO, to remove the grout as much as you can before caulking. – The Evil Greebo Dec 13 '12 at 22:12
