I'm replacing a toilet shut-off valve (clean water flowing into tank) on the first floor of my (100-year old) home. I'm reading that I need to shut off the water, then drain the lines, before making the repair. This toilet is on the 1st floor of a 2 story home, with the water heater in the basement. For example, here it says:
Shut off the water at the main shutoff valve. If you have a gas water heater, turn the knob to the 'pilot' position. Shut off the circuit breakers to an electric water heater. Then open a faucet on the lowest level of your house and another faucet on an upper level to drain the pipes. Then disconnect the supply tube from the shutoff valve. Replace the valve.
We have a gas water heater in the basement. My impression, though it may be wrong, is that if I shut off the water in the house, I also need to shut off the boiler such that it doesn't empty out and try to heat air, creating pressure and possibly an explosion. I could be wrong about this, and strangely enough I'm having trouble finding advice or readings.
My plan is to open the faucets on the floor below the floor with the toilet I'm changing in order to drain the system.
My question is: do I need to set the water heater to pilot, in order to avoid the dangerous scenario outlined above? Doing anything to our water heater makes me a bit nervous.
I've found a lot of advice on how to replace a toilet shut-off valve, but surprisingly little on this specific and incredibly common scenario.
toilet shutoff valve
JaredH
  • 175
    How would it empty? Hot water is drawn off the top of the tank (heat rises, so that's always where the hottest water is), so you need the pressure of the cold water coming in at the bottom to push the hot out and through your pipes. Plus it doesn't sound like you're planning to open any hot water taps, so it would still be a sealed system. – Nate S. Jan 25 '21 at 22:38
    Maybe (probably) I'm missing something - I would open the taps on the floor below the floor with the toilet I'm changing. I'll update my question. – JaredH Jan 25 '21 at 22:47
    Opening cold taps won't drain anything from your hot water heater -- it has a one way valve so that hot water cannot flow out the cold input. And unless you're plumbing your toilet with hot water for some reason, you really don't need to drain out your hot water pipes. – Nate S. Jan 25 '21 at 22:59
    Side issue - the pipe coming out of the wall looks like it could be threaded at both ends (though I think that would be uncommon?) Just in case, when you remove the existing valve take care not to unthread or even slightly loosen the pipe where it attaches back inside the wall, or else it could leak unseen in there. I'd keep a pipe wrench on the pipe as well as a wrench on the valve to make sure it cannot turn. – StayOnTarget Jan 26 '21 at 13:52
  • @StayOnTarget Thank you for the tip. I have a pipe wrench which I'll use for that exact purpose. – JaredH Jan 26 '21 at 15:14
Do I need to set the water heater to pilot, in order to avoid the dangerous scenario outlined above? Doing anything to our water heater makes me a bit nervous.
NO, In the amount of time that it will take you change the valve there will be no issues with it set to the current temperature.
Once you turn the water off, even if someone opened a hot water faucet there would be no water pressure to push hot water out of the water heater (WH), so the WH will not need to fire up.
Once you turn off you main water supply you will want to open all the faucets in the house to bleed out what you can of water in the pipes to minimize the amount of water that come out of the toilet supply pipe when you remove the valve. You can turn it to the pilot setting if you want to feel more at ease, its easy and the pilot will stay on so no need to re-light it.
The boiler is a closed system, except for a one way valve that is designed to add water to the system if it runs low. It will not "empty out and run dry" if you shut of the main water supply for a short time. You can turn off the power to it if you feel you need to.
Alaska Man
  • 13,521
  • Interesting - that makes sense. Yet everywhere I read, such as [here](https://www.familyhandyman.com/project/how-to-replace-a-shutoff-valve/) it says to `Shut off the water at the main shutoff valve. If you have a gas water heater, turn the knob to the 'pilot' position. Then open a faucet on the lowest level of your house and another faucet on an upper level to drain the pipes.` – JaredH Jan 25 '21 at 22:50
    @JaredH, that's needed when you're draining your hot water pipes as well as your cold ones. Since you're only plumbing in a toilet, you don't need to drain your hot side at all. – Nate S. Jan 25 '21 at 23:00
  • @NateS. Makes perfect sense. Thank you so much! – JaredH Jan 25 '21 at 23:01
    I think there is an unstated assumption about whether the repairperson can prevent anyone else in the house from using hot water while the main is shut off. If so, then the project becomes simpler and the lines about only the cold-water pipes being affected are true. – WBT Jan 26 '21 at 13:53
  • @WBT yes, good point. I'm able to prevent anyone else from using hot water during this time. – JaredH Jan 26 '21 at 15:14
  • Are you sure? I once drained water from a water heater of pressure by opening the cold water valves in the house with the main off. The plumber had cut the hot water pipe with the main off expecting no leak, but there was one until I got the water heater down to about half way. – Joshua Jan 26 '21 at 18:46
Yes and no to draining the lines. You really only need to drain the lines enough that you don't flood yourself when you take out the fitting or valve.
All this generally means is to shut off the water and then open a faucet at or below the level of the pipe you're working on. You can verify this by flushing the toilet and seeing if there's any water trying to refill the tank. Once it's dry, you can do your repair with minimal water running out of the valve. You don't need to drain the tank, but if you accidentally pull too hard on the line going to the tank, you could damage or move the seal, causing water to come out. That's pretty trivial if the tank were empty, but a minor catastrophe if it's still full.
With a boiler set up, and even on some tankless heaters, there's often a valve on the out-going side that you can close so water isn't drawn out while doing work.
That said, if this is lower than any other valve or faucet, you'll still need a pan to catch water that comes out when you remove the valve. Even if you do get all the water out, you'll still want to have a towel to catch the drips and drops remaining.
Also, because this is a toilet, it's taking water from the cold water side, not hot, so you shouldn't have to worry about the water heater at all.
computercarguy
  • 1,770
    I hope you're replacing this valve with a quarter turn valve, which is much easier to use, faster to shut off and more reliable and long-lasting than the one you've got. Those are prone to breakage. You will need a 1/2 inch threaded inlet to a 3/8 compression outlet. You might want to replace that rigid line to the toilet with a flexible, stainless hose (7/8" at toilet fill vslve connection and 3/8" compression connection at the shut-off valve. Measure length in advance if shopping. They come in 9, 16 and 20 inches, if I recall correctly. – DAS Jan 26 '21 at 04:55
  • @DAS thank you for the tip. I'll do exactly that. – JaredH Jan 26 '21 at 15:16
The reasons for shutting off the water heater are twofold:
First, if the heater comes "on" while you have things disassembled then the water in the tank will expand and may cause some minor flooding.
Second, and more importantly, if something goes awry and you have to make a run to the hardware store, or some other issue drags things out, the tank may, for any of several reasons, begin to empty out. If the heater comes on with the tank partially empty the heater may be damaged.
It's a simple matter to turn the heater to pilot or turn off the power to it, so why not do it? Biggest danger is forgetting to turn it back on until the next morning's shower.
Hot Licks
  • 2,083
I did this myself recently and it was fairly straightforward. Granted, I have a tankless water heater in a single story home, but I wouldn't be worried about your water heater. The entire time to replace one cutoff valve is maybe 15 minutes tops, ten if you're using a push-on connector (mine were sweated on so I score-cut them off and replaced with Sharkbites). It looks like your connector is threaded, so it shouldn't be a problem. Remove your supply line and open the valve to let it bleed out whatever water it needs, and then remove the old cutoff.
Your water heater stores multiple gallons of water inside and that water is not near boiling. Most water heaters cap out at 140F (or 60C, which is a dangerous level to have it at). You're going to lose some water to attrition over time if you drain the lines, but we're not talking enough to make a huge difference. It would likely take days for the water to evaporate into the empty lines.
Even if it did happen more quickly, modern water heaters have pressure relief valves. It's typically a toggle valve on the side of your water heater. Put a bucket beneath the valve and carefully open it until water comes out (the water will be hot because that's what's inside). This verifies the valve is working.
