Can a 6x6 post be used horizontally to support exterior walls of a shed? 6 x 6 will be supported every 5 ft on a concrete pier.
Asked
Active
Viewed 1,725 times
3Can it? Sure! Should it for yours? No idea! How big is the shed? What's it made out of? What kind of roofing? What kind of loads are you putting in it? [Edit] your post to provide as much detail (without going into a long story) as possible. BTW - if the 6x6 has its long direction horizontally, it's called a "beam", when it's standing on its 6x6 end, then it's called a "post". Using the right terms helps eliminate confusion. It's OK, we all gotta start somewhere! – FreeMan Feb 18 '21 at 16:00
As long as it is a regular type backyard/garden type it should be okay. – crip659 Feb 18 '21 at 16:01
2Does this answer your question? [How to calculate the maximum safe load on a horizontal wooden beam?](https://diy.stackexchange.com/questions/76153/how-to-calculate-the-maximum-safe-load-on-a-horizontal-wooden-beam) – MonkeyZeus Feb 18 '21 at 16:16
Almost absolutely. A 5' span is small enough that there's almost no shed you could build that wouldn't be fine on those timbers. It's only if you're talking 20' walls and a huge roof span that I'd be concerned.
If you want a more confident answer, tell us more about your shed. Size, wall sheathing, floor framing, and other factors are relevant.
Note that they should really be pressure-treated or isolated from the concrete and protected from ground moisture (splash).
- 7
- 160
- 386
