I glued some magnets onto my power drill battery to use for storing drill bits on - but will the magnets affect the battery life?
Chetan Bhargava
  • 238
skybreaker
  • 407
  • 25
For one, the magnetic field generated by the magnets are going to be small potatoes compared to the magnetic fields generated by the motor while in use. Two, battery chemistry is essentially unaffected by ferromagnetic fields of the magnitudes you'll encounter in everyday life. Thirdly, there exist specialty tools that have a big magnet on them out of the factory, designed for drilling holes in large pieces of sheet metal, and those of course have no problems.
Unless the magnet is strong enough to lift several 747s off the ground, it's not going to have any impact on your battery.
whatsisname
  • 2,289
    Considering that 747s, by and large, are not ferromagnetic, those would be some terrifying magnets. – Tristan Jun 24 '16 at 21:16
An 18V (Ni-Cd) drill I personally own has a rather strong magnet mounted directly over the battery (intended for holding extra screws and such). I rather doubt they're do that unless they were reasonably sure the magnet wouldn't cause battery problems.
Compro01
  • 843
Doubt it. I've carried several magnets right on top of my blackberry and all is well. I consider the drill heavier duty than a blackberry so I think the drill will be fine.
Jose Leon
  • 485
    Do you have any data to support your claim? Are you sure the OP's drill battery is the same type as your BlackBerry, or whether or not there is any type of shielding in either device? – Tester101 Dec 23 '12 at 13:46
  • The only part of a modern drill battery likely to be attracted to a magnet is a steel casing. The chemistry inside doesn't care about weak magnetic fields. – Wayfaring Stranger Dec 23 '12 at 14:47
