I want to build shelves into an alcove, but the corners are not square. What is the best approach to this?
Asked
Active
Viewed 7,727 times
16
"Not square" can mean two different things: not a right-angle, or rounded.
If the walls are not at right angles, you can use a T-bevel to measure the angle between the walls. If you don't have a T-bevel, you can hold a piece of light cardboard against one wall and fold it so the crease is against the other, which you can use as a template for cutting the shelves.
If the corners are rounded, I'd use the cardboard again: estimate the radius of the corner, cut a quarter-circle of that radius, and check how well it fits into the corner. If necessary, adjust the estimate and repeat. Then use the quarter-circle as the template.
- 20,739
- 17
- 92
- 133
17Make sure you do this at each height you plan on putting a shelf, just in case your walls aren't the same angle from floor to ceiling. – Doresoom Oct 14 '10 at 13:24
great tips, thanks guys. I have adjusted the question title to be more useful. – Mild Fuzz Oct 14 '10 at 15:04
