How should I mount a TV stand on a wall covered in drywall? Should I trenail it to the wall?
Asked
Active
Viewed 2,460 times
3How heavy is the TV you will be putting on it? Drywall may not be strong enough to hold it without using the wall studs. – chotchki Oct 15 '10 at 12:53
1See also http://diy.stackexchange.com/questions/943/how-much-weight-can-a-drywall-withstand and http://diy.stackexchange.com/questions/1667/flat-panel-mount-on-metal-stud-wall – ChrisF Oct 15 '10 at 12:54
23
I wouldn't hang my TV from the drywall. You really should put it in a stud.
aphoria
- 2,495
- 2
- 19
- 18
1+1 ... definitely should hit a stud ... even the flatscreen TV's are pretty weighty when it comes to drywall, it would probably eventually tear through the drywall. – Oct 15 '10 at 13:52
1Get an inexpensive stud finder or try using a knuckle or a small finish nail to find the studs. – BrianK Oct 15 '10 at 18:04
1Depending on weight of the TV, you'll want to use at the very least something like a #10 2" screw into the studs. Often the wall mounts will come with even bigger lag screws (with a hex head) and again, those go into the studs. – gregmac Oct 24 '10 at 17:50
