The light in my Harbor Breeze ceiling fan stays lit for only 2 seconds. Otherwise the unit works great. What do I need to do to fix this issue?
Cassie
    what kind of light bulb is in there? what is the fixtures recommended wattage and what wattage of bulb/bulbs do you have in there? is it a new fan or existing fan? if it was an existing fan did it just start happening? this is a pretty vague description i would need a little more info to help. could be a few things. – squinny Jan 07 '13 at 02:54
  • Are you tripping a circuit or just the light is turning off? – Scribblemacher Jan 07 '13 at 03:35
  • Could be a loose connection, like once the socket or wiring gets warmed up enough the heat expansion might warp something enough to break the circuit. – Darth Continent Jan 10 '13 at 14:44
  • possible duplicates, or at least worth reviewing: http://diy.stackexchange.com/questions/1511/what-is-the-purpose-of-a-watt-regulator-in-my-ceiling-fan?rq=1 http://diy.stackexchange.com/questions/6938/ceiling-fan-stops-after-a-few-seconds?rq=1 – mac Sep 30 '13 at 18:14
The bulb wattage is too high. Try moving the wattages down a notch and this should alleviate the problem.
user14342
  • worth reviewing: [What is the purpose of a watt regulator in my ceiling fan?](http://diy.stackexchange.com/q/1511/6742) – mac Sep 30 '13 at 18:15
I came here after just having this problem. Mine was a bit sillier: the light bulb I was using has an automatic sensor that shuts the bulb off in the presence of light. You know, to be economic if you leave the light on.
Brandon
The light on my Hampton Bay fan would come on for 2 seconds, then shut off. After uninstalling the remote receiver the light worked perfectly. I don't have a remote anymore but that's ok.
mike
  • 3,010
Jeff
