How can I fix this deep scratch
Asked
Active
Viewed 36 times
Fixing it like new is not possible without replacing board. The surface is too damaged. Can use a coloured filler to kind of cover it, but laminate is very thin and you have gone though it to base wood. – crip659 Apr 12 '21 at 11:36
Can see this link for some ideas. https://diy.stackexchange.com/questions/147895/mend-scratch-in-laminate-flooring?rq=1 – crip659 Apr 12 '21 at 12:03
1Does this answer your question? [Mend scratch in laminate flooring](https://diy.stackexchange.com/questions/147895/mend-scratch-in-laminate-flooring) – FreeMan Apr 12 '21 at 16:08
Laminate doesn't generally get fixed, it gets replaced. Luckily it's damaged parallel with the grain. You *could* get some stain which matches the floor, try to apply it with something thin like a toothpick, and brush off any excess. Just have to be careful not to stain the surrounding undamaged floor. Good luck! – MonkeyZeus Apr 12 '21 at 17:30
