-1
I am installing an underground waterline for irrigation by tapping into the home water line. Since I have well water I don't have a water meter. However, I would like to install a simple but accurate water meter (or similar type device) in the basement before the line exits the house so that I have peace of mind that there isn't a break in the water supply between my house and the garden faucet 160 feet away. Any suggestions?
Thank you!
math314
  • 77
  • Not VTC, but I think the question should be rephrased to ask about the actual problem, which is detecting a break in the outdoor water line. Generally, post the problem, not your proposed solution. – Chris Cudmore Apr 29 '21 at 14:52
A definite solution to monitoring your line for leaks would be to install a meter.
If you google "water meter", you'll get a list of all different types.
Here is one I found after a quick search:
I'm not endorsing this product and have no affiliation with the company.
JACK
  • 78,739
  • 72
  • 188
    I would add a shutoff prior to the meter incase of problems in the future. That is a good price. – Ed Beal Apr 14 '21 at 13:44
