How deep do I need to make the post footings for a residential deck in Northern Michigan? The 12" X 20" deck will be less than 2 feet off the ground.
2It does not have anything to do with the height of the deck off the ground. It does with the dimensions of the posts, 6X6 vs. 4X4s.. The depth of the frost line has to do with how deep the posts go. In Michigan, I suspect it would be quite deep, maybe 4 feet down. – Jack Apr 15 '21 at 14:40
1Do you really mean a 12 inch by 20 inch deck (i.e. 12" by 20")? It seems like you may have intended 12 foot by 20 foot (i.e. 12' by 20'). – Makyen Apr 16 '21 at 00:19
@Makyen He already has a people deck. This one is for his pet mouse. – K H Apr 16 '21 at 05:00
The post depth depends on the frost line. The size of the footing depends on the soil type under the footing.
You need to dig until at least under the frost line, and then, if you are not on rock or undisturbed/compacted soil, dig until you get there. You can analyze the soil as you dig. The size of the pad of your footing depends on the soil: gravel, sand, or clay. See also https://www.decks.com/how-to/articles/soil-conditions-for-deck-footings
Check with your local municipality, they have this info for you.
Here's a map of the frost line (depths), and you'll see that Michigan is around 55".
From https://www.decks.com/how-to/articles/deck-footing-frost-depth-map :
Always check with your local building inspections department to see what is required in your area. Furthermore, you must install footings at least 12” below unsettled soil. If you are building into the side of a steep hill or beside a retaining wall you will have to maintain the minimum distance to grade not only vertically but also laterally. In order to achieve a suitable lateral barrier you may need to dig your foundation much deeper than on a flat surface.
- 15,754
- 28
- 51
2The key is to check with your local building department, permit required or not. They'll tell you the exact minimum depth you'll have to go. – FreeMan Apr 15 '21 at 16:10
2@FreeMan yes I'll edit and bold that text. It's really easy info to get. – P2000 Apr 15 '21 at 16:24
Your best first resource would likely be the permitting requirements for your county and the county inspections office. Their website and their staff would provide the requirements as well as have the experience to guide you about the typical challenges and solutions given the climate, soils, and topography. In most jurisdictions a deck less than 30 to 36 inches off the ground does not require permitting. But the recommendation is to educate yourself on them anyways. It will help you to formulate a solid design.
Additional resources might be your local landscaping supplies distributor. They will have experience working with similar projects and understand the appropriate materials and methods to employ.
To fully address the question - and if by chance permitting were required (e.e. due to slopes) you would want a site and soils analysis by a geotech. That's probably not in your plans due to expense so you might do a little of the similar legwork they would do on your own. Do a few soil borings yourself to verify what you're building on top of. When you know what you're working with that will help to look online for the strength of that soil and also what kinds of piers are best to use.
As the commenter mentioned you will need to go fairly deep in any case just to drop below the frost line: so the depth is probably sufficient. You will likely have multiple options available for the types of footings to use: though the standard concrete piers you are likely considering would seem to suffice since you have not mentioned any sloping considerations.
- 711
- 5
- 17
Unfortunately, the anecdotes heard and repeated by staff at big box stores is quite often rather wrong. It's not that they're bad people intentionally steering you wrong, it's just that they don't know and simply repeat what they've heard, right or wrong. – FreeMan Apr 15 '21 at 16:35
That may be fair here: it is a more involved project than most of them would do. I have worked directly with manufacturers and distributors on more complex problems than this one which is somewhere in the middle. – WestCoastProjects Apr 15 '21 at 16:40
It might be worth reconsidering if you even need to use cylindrical poured footings. Have you looked at the possibility of using Diamond Piers or Helical Piers? A lot of municipalities are starting to allow these alternative options, and there is a lot of evidence that they are just as effective as the traditional concrete footings. They cost a bit more, but the installation (I am assuming you are doing this yourself, or you wouldn't be asking the question) is far less labor-intensive.
Your typical 12" cylindrical footer will take at least 4 bags of concrete, without having the bottom belled out. Imagine trying to dig a hole for these suckers with a post hole digger:
No thank you.
This guy is installing Diamond Piers. He isn't even sweating:
If you are wondering, there is a good amount of evidence that these don't have issues with frost heave, which you might expect from a shallower footing.
Helical Piers are a third option. They may require some equipment to install, but can also be driven about as deep as you would ever want. They will support almost anything:
heavy equipment is not always necessary. You can probably rent these:
if they don't need to go too deep, you can get away with using a 2x4 for leverage and drive them by hand.
I personally would be more than happy spending a few hundred extra dollars on the total cost of a deck, if it meant that I wouldn't have to pour footings. If you decide to look into either of the Diamond or Helical piers, make sure to check with your city inspector first.
- 1,490
- 7
- 12
Is it a thing in some counties _not_ to accept piers? They're very strong, can go deep and are more durable. For raising the foundation of my house that was the only way to go. The older concrete piers already in place were adding more weight to the home causing it sink more. Why? Those piers were dug down two feet below the foundation . They were sitting on unstable dirt and continued to settle. The piers were dug down another five to seven feet to hit bedrock. – WestCoastProjects Apr 16 '21 at 04:54
I'm looking into Diamond Piers: can they be installed by the DIY'er? – WestCoastProjects Apr 16 '21 at 05:02
My city (at least as of 2016) doesn't allow diamond piers for deck footings. Every other municipality within 100 miles is fine with them. And yes, they can absolutely be installed DIY, but you'll need to rent a jackhammer (or own one, but who owns a jack hammer??). It's definitely some work, but it still beats burying those belled out sonotubes. – Z4-tier Apr 16 '21 at 05:59
