I am wondering if it is possible to cut the protruding part of the window sill here (see picture) such that my wall would be entirely flush. I am looking to fit a bespoke floating desk which would go right against the wall.
What are the risks here? Is the protruding part critical to the window stability?
Side-hinged window with sill slightly proud of the wall
Chenmunka
  • 1,296
Unless you get into either the mechanism or the seals of the window you can carve it up however you like. It's unlikely to be a structural concern.
Actually, that sill probably isn't part of the window to begin with. Jambs, stops, and sills are usually not part of the package. If it is part of the actual window, you may find a hollow which you'll have to cover with your desk or other trim.
If you decide to go forward, cut the caulk and/or paint all the way around that sill piece and give it a tap upward with a hammer. It may come free so you can remove it, run it through a table saw, and reinstall it. A fine bead of white painters caulk will have it back in place like new.
  • A table saw is the _preferred_ way to make this cut, but a circular saw will work if you don't have the table saw. Just use care as you're balancing the circular saw on a fairly narrow piece and it'll be easier for it to tip, giving you a divot in your cut. You also have to deal with clamping issues - the base of the saw will run into a clamp somewhere... Don't use a jig saw - [it won't make a straight enough cut](https://diy.stackexchange.com/questions/198068/198073#198073) and you'll be mighty disappointed. – FreeMan Apr 21 '21 at 12:07
