Following the suggestion here, I did a little searching and found two options for bug spray: an off the shelf product or DIY. In terms of per ounce active ingredients, the off the shelf solution is about ~10 times more expensive. I'm wondering if I go the DIY route, are there any additives I should add to increase the retention/longevity of the active ingredients in the perimeter barrier, like surfactants and ammonium sulfate for glyphosate?
Asked
Active
Viewed 436 times
How long are you targeting between applications? When I used Bifen as a barrier, I had excellent results with a 4 month schedule in a wet and sunny environment. For longer than that, you could try fipronil as a barrier. – Eric Hauenstein May 25 '21 at 13:19
Certainly the longer the better (hence the question) :) But 4 month sounds long enough! Was that just Bifen without any adjuvants? – Roc W. May 25 '21 at 15:58
Yes, in fact that identical product if I recall correctly. It may depend on the pests in question, which were cockroaches in my situation. I also recall that I used one of the richer mixture ratios as specified on the label, which may have contributed to the longevity. This did make the dried product have a faintly milky residue, but this was a non-issue for an outdoor perimeter spray. – Eric Hauenstein May 25 '21 at 21:03
With credits to reddit, there are a few adjuvants to mix with Bifen:
Insect growth regulators: Pyriproxyfen (Nyguard), Methoprene (Precor).
Pesticide synergist: piperonyl butoxide (Exponent).
Wettable powders formulations are often longer lasting.
Roc W.
- 363
- 2
- 13
