Can you run a 14/3 to feed two separate zones of lights? Two breakers Two hot legs feeding 2 lighting circuits each with their own switch, and share the neutral?
Asked
Active
Viewed 43 times
1See [What is a multiwire branch circuit?](https://diy.stackexchange.com/questions/71652/what-is-a-multiwire-branch-circuit). – isherwood Jun 23 '21 at 16:02
Two breakers *but you have to handle-tie them*. But yes, I do exactly that in my shop. Also in many locations they will need GFCI or AFCI, doing that on tied breakers will be complicated, hard and expensive. – Harper - Reinstate Monica Jun 23 '21 at 21:30
If I can would I be better of to run 2 14/2’s? – Angus Mcintyre Jun 23 '21 at 23:56
