30
I'm planning to mount LED strips under the treads of the outdoor wood staircase to our back yard. I'd like to avoid light shining into peoples' eyes while climbing stairs, so I'm considering mounting the LED strips in a 45-degree aluminum channel with the beam pointing back at the risers. My goal is to make the light source effectively invisible, even from the bottom of the staircase. Here's a not-to-scale rough idea of what I have in mind.
Is this a bad idea for any reason? For example, is it dangerous if most of the illumination is on the riser and the back part of the tread instead of on the front part of the tread where people step onto? Or is it more safe because people won't be blinded by the lights so are less likely to trip?
I've never seen LED strips mounted like this so I'm a bit nervous about it. But I also really like the way it looks! Here's a mockup I built tonight.
Justin Grant
  • 1,577
    another option is to pick a lower intensity light, (or dim these strips) so that people can look straight at it without losing their night vision – ratchet freak Jul 16 '21 at 08:04
  • @ratchetfreak - Yep, I tried that initially. I observed less about losing night vision and more about the stark contrast when walking up steps between the bright part (the bottom edge of the risers) and the dark part (everything else). I thought it made it distracting on the way up. Using indirect light let me turn up the dimmer a little which seemed to illuminate everything better. The tradeoff may be on the way down, because I suspect the far edge of each riser may be a bit dimmer. But I haven't mocked up enough stairs to be sure one way or the other. Hence this question. ;-) – Justin Grant Jul 16 '21 at 12:29
    Re: *"I've never seen LED strips mounted like this"*. Personally I have seen it at hotels, resorts, restaurants and a few other places; a quick google image search for "LED stairs" shows that this is a quite common configuration. I think it looks good, best of luck with your project. – Aubreal Jul 16 '21 at 17:44
  • @AlexandreAubrey Movie theaters, too. It's a great configuration for stairs that will be used in the dark. – GammaGames Jul 16 '21 at 21:53
    There's what you come up with that works well, and then there's building code compliant. You probably want to check out what the local building code has to say. – Technophile Jul 16 '21 at 22:09
    you should have other outdoor lighting to balance the light; if the only light source is the stairs, it will be hard to see anything else when ascending if there's no "counterweight". Ambient light also serves to pre-constrict the pupil at night, preventing the high-contrast stairs from dazzling a dark-accustomed eyeball. The stair idea is neat and can be the star of your show, but add a few support cast to tell a more broadly digestible story. – dandavis Jul 17 '21 at 07:39
  • Do you intend on carpetting? You might have clearance issues if you put the light in first without knowing how much space the carpet/underlay will take. – Criggie Jul 17 '21 at 12:23
  • _"pick a lower intensity light"_ or use red light as that cannot blind the observer? – Torben Gundtofte-Bruun Jul 17 '21 at 14:47
  • In my house I just used glow-in-the-dark tape for such cases. It's almost invisible/white during the day, but glows at night. For example, I've outlined the whole bathroom door and put another strip in the middle pointing to the door handle. This way you know whether the door is open or closed and where the handle is. – Ark-kun Jul 17 '21 at 20:56
    Maybe it's just the lighting of your picture, but it looks to me like it's hard to see the outline of the nose, which may snag on a shoe. – Sittin Hawk Jul 17 '21 at 22:37
    What does your mock-up look like from the reverse angle? I'm not nearly as concerned about falling *up* a flight of stairs from the bottom as I am about falling *down* one from the top. – A C Jul 19 '21 at 00:07
  • If you like it, it's good. – Kyle B Jul 19 '21 at 01:56
  • What is your goal? Make it look good, or illuminate the steps so you can use the stairs in the dark? – jcaron Jul 19 '21 at 07:57
    As someone who badly broke their ankle *descending* a staircase, I've upvoted @AC [comment](https://diy.stackexchange.com/questions/229237/is-is-safe-to-use-led-strips-that-shine-onto-stair-risers-instead-of-directly-on#comment437561_229237), but alas only once! – gboffi Jul 19 '21 at 10:41
  • Because you want enough illumination to reveal the tread and nose, the glow of white LED's is still too much . I Googled 'outdoor stair step lights' and looked at images, yellow seems ideal, red may not be bright enough. Have you considered not running the entire length of the tread? Either just on ends or in center? –  Jul 19 '21 at 12:33
  • Dropping this link (found it on a different stackexchange) on stairs where one step is off: https://www.youtube.com/watch?v=seieuz__B_g The guys there trip since the one step near the top is slightly larger – masterX244 Jul 19 '21 at 13:34
10 Answers10
35
I really like the way your mock-up looks!
Additionally, as one whose eyes are extra sensitive to bright light, I would significantly prefer that to having any chance of light shining directly into my eyes.
Even if the edge of this step isn't perfectly lit by the light above it, it's location would be intuitively obvious to all but the youngest child by the location of the light below it. It's perfectly obvious that you simply step above where the brightest light is, and, after the first step, your brain will calculate the distance between the location of the light and the top of the tread above and will compensate. Us humans, we're pretty adaptable that way.
  • Thanks! I like it too. :-) Your logic about stair adaptability seems reasonable to me. – Justin Grant Jul 16 '21 at 12:34
    Do note, I'm not sure about any code compliance issues, but considering how many stairs are _not_ lit at all at night (at least not full time), or are (in my opinion) very poorly lit, I think you'd be just fine here. – FreeMan Jul 16 '21 at 12:51
    Most people, even small children, have no problem negotiating stairs up or down even in near or total darkness, as soon as the first step is taken and they have a got feel for the height of the riser and the depth of the step. As long as the steps are straight and regular in size there is no problem. Any light just makes it easier. – Tonny Jul 16 '21 at 13:06
    @Tonny I agree. My "youngest child" comment was really directed toward those who aren't particularly good at navigating stairs even in full sunlight yet. They'd most likely just get picked up & carried. ;) – FreeMan Jul 16 '21 at 13:16
  • "Obvious to all the but youngest child" is definitely a comment from someone who hasn't had vision problems. – Dragonel Jul 16 '21 at 16:16
    @Dragonel I have an eye-problem due to which my depth perception is severely limited nearby (10 - 15 foot). I have to be VERY careful to step on the first step of any stairs because I may miss te step completely. Especially going down overstepping is really dangerous. But as soon as I’m on the stairs there is no issue at all. – Tonny Jul 16 '21 at 16:38
  • @Tonny My father's vision was much the same, but while the "regular sized" steps were usually okay, the overhang on some steps (where the light is for these) could also catch his foot and sometimes the stairs are not regular, so he had enough "near misses" to reduce his confidence in any stairs he hadn't been up & down at least 10 times. – Dragonel Jul 16 '21 at 17:16
  • @Dragonel Unfamiliar stairs I always take very carefully, especially the first 3-4 steps. Feeling with my toes where the riser and the lip of the steps are. After a few years it has become an ingrained habit. I do it more or less automatically without even thinking about it. – Tonny Jul 17 '21 at 12:13
    If your stairs are made properly, people will adapt after the first step even with no lights. There are standard regarding stairs and they must be consistent, or people will trip on "nothing". – Nelson Jul 18 '21 at 05:43
  • @Nelson: And even if the stairs _aren't_ consistent with other stairs, people still adapt within the first few trips up and down. – Vikki Jul 21 '21 at 23:55
    @Vikki I'm not talking about consistency with **other** stairs. I'm talking about consistency with **itself**. If one of the steps is different height by half an inch or more, people will trip. [This New York stairs](https://www.nbcnewyork.com/news/local/subway-stair-tripping-people-fall-steps-brooklyn-station-36-street-sunset-park-mta/1948751/) was made with an improper variance of half an inch in one step, while the regulation maximum is 3/8. People will trip on incorrectly made stairs. – Nelson Jul 22 '21 at 01:37
I don't see any problem with mounting them in that way.
Effectively you just use them as indirect lighting. They still provide some illumination to the steps themselves, just at lower intensity.
Just make sure your aluminum bracket doesn't make electrical contact with the LED strip. (I would put a layer of water-proof insulation tape on the inside of the bracket before mounting the LED-strip to it.)
Tonny
  • 745
    I'm sure somewhere there is a really badly made LED strip that has issues, but even basic issue budget strips are still finished on the back and have no problems in this kind of bracket. Also, the brackets are kind of a snug fit, not a lot of extra room for anything (assuming you get the size of bracket that matches up to the width of your LED strip). – user3067860 Jul 20 '21 at 00:27
It's a bit 'form over function'. It's the kind of lighting bars trying to look 'cool' use & which three drunks a night fall down, because they can't figure out where to step.
Would it not be simpler [& probably far easier to see the stairs] to run the strip light [blue line] up the side of the staircase, angled down in a similar manner so it can't be seen from above?
'scuse the 'fine art'…
One strip of LED to encapsulate, one cable at one end.
If you wanted to be extra safe for those with limited vision, contrasting safety tape can be placed at the leading edge of each step. Maybe white, or if that feels a bit garish, black 'grip strip'.
Tetsujin
  • 10,454
  • 37
For someone who is partially sighted and doesn't have depth perception, it may easily look as though the lighted riser is the part you are supposed to step on. Do you remember those optical illusions and pictures where stairs will suddenly invert?
I'm not saying not to do it at all, but please be careful in your implementation & try looking at it in low-light or through just one eye, or through blurred glasses and envision it for those whose vision may not be as good as yours.
Dragonel
  • 191
    Fair enough point. I would imagine that A) you have to make some adaptations to a house you move into, _or_ B) have to take some time using extreme caution as you adapt to said house, _and_ C) use the same extreme caution and/or a guide when in an unfamiliar locale. Had a friend who was basically blind in low light - we were always accommadating to him, except when we were messing with him... :D – FreeMan Jul 16 '21 at 16:26
This is not an uncommon configuration. Case in point: there's a home renovation tv programme in The Netherlands, that is sponsored by a staircase renovation company. It has become a joke by now that each and every time, it just so happens that the staircase needs a renovation. The last couple of seasons has nothing but this design.
So if professionals do it, it must be not completely idiotic.
I would recommend doing it on every step, though, since the light makes it harder to see the parts that aren't illuminated. You might want to think about a solution for the landing as well.
SQB
  • 878
    Just curious, are you talking about "Kopen Zonder Kijken"? I must admit I've never watched that (or anything similar, really). – TooTea Jul 17 '21 at 08:00
    Nope, it's _VT Wonen: Weer Verliefd op je Huis_. It used to be just the stairs, but lately they've found ways to replace at least one door with a black steel and glass one, and the latest sponsor seems to sell blinds that can be controlled with your phone. At least, those are the ones I've caught while it's on in the background, I don't like the show but someone else in my household does. – SQB Jul 17 '21 at 08:21
    @SQB All of those DIY/Home Improvement/Life Style shows on the Dutch commercial TV channels are just advertisements with just enough show around them that it doesn't run afoul of the advertisement regulations. Same goes for the Belgian channels (those are owned by the same media groups) as well. I stopped watching that drivel years ago. – Tonny Jul 17 '21 at 12:09
    Double stress on the "every step" point. If you do e.g. every other step, it's confusing to the eyes. If even one step is missing its lights, it can mess your head up and likely cause people to trip. The most important feature that any staircase needs to have (after structural stability) is *absolute consistency*. This may be less of an issue with the back steps at your house, but is especially true of stairs in a public area used by lots of people. – Darrel Hoffman Jul 19 '21 at 13:50
IMHO, you
  • want to make sure the parts one treads on are best illuminated. Most importantly the front edge and not the riser.
    You can get there by adjusting your shade(s).
  • LEDs are usually built so that they emit most intensity perpendicular to the mounting surface. I think it may be worth while experimenting with mounting the strip tilted towards the edge of the next step to get more (most?) intensity there.
  • A vision impaied friend tells me the most difficult thing for them is that stairs downwards often look all the same color/brightness to them (this already happens during daylight conditions).
    This would suggest that you want to produce a contrast at the edge when seen from above. I.e., brighter illumination of the edge and more dim light towards the riser in order to best illuminate the most important part.
  • The darker the material of your stairs, the more light you need to illuminate them. And the more blinding that light if it gets into the eyes of someone going up. While you'd ideally restrict the light to fall only on the next step, in practice also somewhat more flat angles are OK: it is sufficient that someone standing before the first step is not hit directly by light from the highest step.
  • (outdoors stairs have additional considerations because of reflections on wet surface)
  • IMHO if you do such an illumination, you also need a solution for the first step going down. Falling/stumbling at the very first step downwards is the worst case for accidents on stairs. Where I am, first step down is considered sufficiently important that it will be marked in workplaces etc. (by striped band) in many cases where no other step is marked.
  • the key to not blinding people by the illumination of the stairs is to have that illumination in a good relation to ambient light.
  • color is important, too: blue LED stripes may look cool, but many people have difficulties focussing blue in the dark. I'd probably go for orange on wooden stairs.
  • As someone with excellent night vision which however needs its time to fully adapt to low light conditions, I'd vote for a very dim solution plus dim ambient lighting, e.g. like Tetsujin suggests (also mounted so that the light goes downwards).
    You definitively want to ask people with poor night vision as well, though.
  • I'd think of putting the stripe into a groove (if practically possible) or making the front shade very sturdy.
    One doesn't believe where people inadvertendly kick things into pieces unless one sees it...
It looks cool, but it's not very useful. The part of the stair you're lighting -- the risers -- are the one part that isn't important to someone using the stair. They need to see the treads (which will be quite dim), and in particular the nose (which will be the least lit of all). Essentially, you're asking them to "only step on the parts they can't see".
While I have seen this sort of lighting before, it is used in combination with other light sources (in particular, wall-recessed ground lights with downward baffles). If you insist on this, I suggest that you have only a shallow baffle in front of the light, and probably a baffle behind it as well, such that it illuminates the tread at least as much as it does the riser.
Sneftel
  • 529
Make sure you dim the LEDs properly. Those lights must be good to add design and provide visibility to the stairs so people don't fall. They don't need to illuminate. Make sure that, with a proper dimmer, the lights are not bright enough to illuminate the space and blind the people. You may want to illuminate the space with something else than those LEDs
With "mounting the LED strips in a 45-degree aluminum channel" and going up the stairs now has a bigger hook to catch shoes.
This arrangement produces less glare than you'd get from an exposed LED, but the top of the riser is still brighter than everything else. This doesn't seem ideal.
What if you still pointed the LEDs down -- or, better yet, angled them so their beam pattern was more centered on the tread -- and then just used your angle strip to block direct glare anywhere beyond the tread? That would shield eyes from direct glare, but it would put more light onto the treads where it's needed.
jeffB
  • 111
