What is round box near my water meter? I'm trying to increase the water pressure to my house, which was built in 2019. I know that the water pressure is lowered to my house and sometimes there's a water pressure regulator whose nut can be turned to increase water pressure. I tried to turn the nut on the box near the water meter (see attached image) but it won't turn. Any help would be appreciated. Thanks, David
Asked
Active
Viewed 209 times
There's a high likelihood that it's a cap for a clean out. Does the sewer line run near here too? – FreeMan Sep 30 '21 at 16:31
1Dig it out more. Looks more like some kind of filter, but it's not something I'm familiar with. Since it is close to the meter, someone at the water department might be able to tell you. – JPhi1618 Sep 30 '21 at 16:43
2What is the water pressure in your house and how do you know it's a pressure problem vs. a flow problem? – jwh20 Sep 30 '21 at 16:43
1BTW - If that device, whatever it may be, is on the water main side of the meter, it's the property of the water utility. They will not appreciate you messing with it. – jwh20 Sep 30 '21 at 16:48
