I am building a shed and like most sheds, the floor frame is on blocks, so there is a space of about 10-12 inches under the shed. I know from previous experience that foxes and rodents like to use such spaces. How do I keep animals out from under there? If you just put a skirt board down or something like that, then the animal just burrows under it.
Asked
Active
Viewed 1,197 times
mix broken glass into the dirt to discourage digging for cheap, then you can take up above-ground space with crumpled chicken or barb wire. – dandavis Nov 04 '21 at 20:01
broken glass is just too cruel – jsotola Nov 05 '21 at 00:44
Some ideas:
- Lay heavy landscape fabric or galvanized hardware cloth and rock under the entire area.
- Leave the space open enough that it doesn't appeal to den-seekers.
- Install a skirt and place a row of pavers or large rocks around it.
- Install wire mesh down to the ground and then outward a foot or so. Cover it with skirting and landscaping.
- Install wire mesh to the ground and beyond, buried at least 12". cover with skirting.
- 7
- 160
- 386
