Update - Thanks for all of the answers and comments - I am including some more info and pictures to try to give a better sense.
A professional is coming tomorrow to take a look, they are the one who gave me the idea to try to replace the old burner myself in the first place - according to them it is completely legal in my area and they are happy to inspect if it is done correctly. I'll also add that we bought the house recently, and as far as I can tell the gas fireplace could not have been used for at least 10 years.
I’m trying to install a new gas burner on an old gas fireplace. There is a rigid gas line that comes up from the basement. From that point it is hidden behind a wall, until there is a valve key/escutcheon. There is a ball valve on the rigid line in the basement which is closed. I've tested both that valve and the valve key - no gas currently flows unless both are open, so seems like we are safe there. At some point behind the wall the rigid line must be connected to a flexible appliance connector. There was an old, very rusted burner attached at the end, and when I tried to get it out I accidentally broke off the end of the flex connector. I can only reach about an inch of the end of the ripped line, the rest is behind the fireplace and wall, inaccessible.
Is there any way to safely connect a fitting or anything else to the line?
Rigid line from the basement with closed valve: enter image description here
Valve key and fireplace with stub of the connector visible: enter image description here
Gas line stub:
Old burner: this was previously attached to the connector, I've since removed it as well as the fake brick wall to give more access to the gas line:
Thermidor
  • 93
    Gas(natural or propane) is one of those things that need to be done right, no make do things. You already broke part of the line, need to know the rest is perfect before using. – crip659 Dec 15 '21 at 16:55
    Let us know in an update whether you were able to get in the space, connected and working. Would be valuable to many other readers. With your valve *before* the connection it's easier to test (very important) and cautiously start operation. – P2000 Dec 15 '21 at 20:40
    Perhaps you could sketch the situation better, for everyone here trying to help: draw the walls, building materials of wall, the gas line, and include all details like size/type of tubing, valves / shutoff, distances, size/type of fireplace etc... – P2000 Dec 16 '21 at 19:17
6 Answers6
38
I would heartily suggest hiring a professional.
Where I live what you are doing is actually illegal.
Your territory may have different laws, but guessing with gas is never a good idea. It goes bang!
After comments, [many now deleted] hinting this may be a 'nervous response' or even 'not an answer'.
This is a Frame Challenge.
If you have to ask, you don't know enough about it to do it safely. You are certainly not qualified to handle live gas, which in most territories is likely to invalidate your house insurance & in others could bring prosecution.
Hire a qualified professional.
Tetsujin
  • 10,454
  • 37
    Agreed. This is a time to pass on the DIY and get it done right. The whole neighborhood could be at risk. – FreeMan Dec 15 '21 at 17:09
    +1, I also added my own answer too because the above could apply to many other DIY tasks like electrical work, and we are still here to support them all. This particular post (and we've seen electrical ones too) strongly suggests it is -as you point out- out of the realm for this DIYer. – P2000 Dec 15 '21 at 17:58
    Interesting downvote for my suggesting someone doesn't blow themselves sky high. There is always the very obvious proviso with gas - if you have to ask you don't know enough about it to do it safely… so don't do it. – Tetsujin Dec 15 '21 at 18:15
    @isherwood - surely that is territory-dependant. In the UK what the OP proposes isn't just downright dangerous, it's actually illegal. This isn't a 'nervous' response, this saves lives. Now the pictures have been added, this is a bomb waiting for one more DIY 'fix' before it goes off. – Tetsujin Dec 15 '21 at 19:18
    @isherwood - I'm not questioning **your** competence, I'm questioning the OP's & anyone else searching this question. Also, your legal status as regards DIY on gas depends on your territory. As we don't know the OP's, then I can only state for *mine*, the UK, where this is **illegal** to DIY. – Tetsujin Dec 15 '21 at 19:47
    I have to agree with @Tetsujin on this one, I've been on a BOC gas safety course, and one of the first things they show you is what happens when it goes wrong. You see a truck with just the cab & a pair of legs where they were transporting propane. One of the cylinders was leaking, the driver lit a cigarette and boom! The entire side of a building missing when an oxygen cylinder was mishandled, fortunately, the 2 workers were unharmed. And a piece of train track missing from a leaking Liquid Oxygen tanker. I would say getting gas wrong is more deadly than getting electricity wrong. – spikey_richie Dec 16 '21 at 08:25
    @isherwood - if it is illegal where OP is located, then it's illegal. Usually things are made illegal for good reasons. Maybe we're more cautious/sensible on the right of the Atlantic, I'm not sure... – Tim Dec 16 '21 at 11:48
    @isherwood - It does address the question, head-on. It says don't DIY gas, most especially if you have no clue what you're doing. This is known [& I have now added into the answer] as a [frame challenge](https://meta.stackexchange.com/questions/263661/does-stack-exchange-allow-for-answers-which-question-the-validity-or-stance-of-t). – Tetsujin Dec 16 '21 at 15:02
    @isherwood: A valid answer to "Can I do xxx safely" is "No, you can't do xxx at all because it's illegal, whether you do it safely or not". (Such an answer may or may not be _correct_ in any given situation, but it's not really fair to say it doesn't address the question.) – psmears Dec 16 '21 at 15:06
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/132429/discussion-on-answer-by-tetsujin-can-i-safely-connect-barely-reachable-flex-gas). – BMitch Dec 18 '21 at 16:16
13
If the pipework broke there, who's to say what its condition is like further inside the wall? That apart, you're asking what to do. That means you're not qualified or experienced. O.k. There's a way to get experience, but not at the price of someone's life/limbs or property damaged. This just isn't where to cut your gas-fitting teeth. Leave well alone, it's going to be money well spent. Or cost you dearly when it goes bang.
Tim
  • 5,198
I hate working with gas - and would strongly recommend getting a pro to fix it.
The pipe does not look in good shape either - I suspect the "proper" fix will be to replace the last piece of pipe into your hearth with a longer one, to give better access and also confidence in the pipe.
That may mean pulling the pipe back out through the bricks and re-doing with modern materials, and re-grouting around the entry.
And since you're going to that much effort, may as well replace as much of the gas line as you can reasonably get access to.
Criggie
  • 10,046
(Edited based on added information from the OP)
As a DYI-er you could do gas fitting under supervision and inspection, and in readily accessible spaces. But if the space is tight, and you are unable to recognize from your own knowledge and experience what details for gas fitting must be provided up front in such a question, it's time to get a professional involved. As a DIY who hasn't done this you can't really see or assess what is fitted/sealed right/wrong especially in tight spaces, whether fitting are compatible, and whether any code or requirements have changed in your region.
  • DIY but also get a professional involved (as you have now done - good move). Be prepared to pay for consulting and an inspection by the professional. It can be an informal "ok", but if you get an inspection letter that would be best.
The consulting up front will allow the pro to specify things like what fittings and materials you need and also to inform you about things you did not know that you had to know, like compatibility, pipe diameter, flow/pressure regulators, shut offs, and any upgrades that would make sense to implement now that you are involved with gas work anyway.
It is possible you have to do more work to replace other sections of the gas lines, and this is your chance to learn about it and do it right.
  • The ugly part: determine whether you need a permit from your local authority and whether the home insurance requires an inspection (these two can be different requirements). This usually just requires a few phone calls. Then decide what you want to do with that information.
A pro would speak from tons of real life training and experience -not youtube-, and most importantly (s)he would bring liability insurance. Also, without a permit or at least a qualified inspection your home insurance likely will not cover this repair or install. This matters for peace of mind around your asset value, the risk you pose to loved ones and neighbours, and possibly the resale value.
  • Get educated (my personal first joy of DIY work). Knowing what work is required, what fittings etc..you are armed with the right questions. Read up on it, watch videos, ask at your supplier etc... when in doubt or whether information appears ambiguous or contradicting, check back with your pro. Since you have a consulting/inspection arrangement they are in the best position to give you advice they can stand by and sign-off on.
  • Prepare a test procedure and start testing: include pressure testing (if required), bubble testing, stress/torque testing etc... Since you have two shut off valves in the path to the fireplace, you can work in stages without shutting off the gas supply for the entire house.
Torquing should not be underestimated: some fitting require specific torquing to tighten for a gas seal, other fittings can and should sometimes be banged with a hammer on a wrench to loosen without cracking the pipe elsewhere. I'd check in advance.
  • Where the work is difficult to reach, first practice on the comfort of a well lit table or work bench. You need knowledge and skills when it comes to fittings, tightening and sealing, and in comfortable well lit conditions you'll have more patience to inspect thoroughly and keep trying until done right.
  • Have it inspected, and enjoy the Holidays in the warm glow of your upgraded fire place which you can proudly and confidently claim to have installed yourself, done right. That's the third joy of DIY.
Gas work, framing, electrical work and plumbing (esp. drains) all require meeting specifications and safety standards. The risk assessment is different for each of these areas. For instance, safety with electrical work can be met if rules and specifications are closely followed, and this site can help get you there. Also, problems with electricity often show up during use, in the presence of observant users who can take action to remediate. (This can be argued, but I hope my point is clear in light of DIY sites providing help with electrical vs gas work)
In contrast, gas leaks can happen regardless whether the fireplace is in use or not, and in spaces under floors and in walls. Moreover, failures occur like a time bomb waiting for windows and doors to be closed, enabling a fuel build-up. This type of hook-up is not the same as an outdoor barbecue or gas fire pit.
PS: oh ya, the second joy of DIY? Tooling up!
P2000
  • 15,754
  • 51
    This makes a lot of sense, thanks. One clarification I would add is that there is a gas valve key/escutcheon beyond this point, so there would only be gas flow when the fireplace is in use. – Thermidor Dec 15 '21 at 18:47
    @Thermidor If it is the gas valve in the second picture don't count on it or any of the pipe. That is bad looking pipe. – crip659 Dec 15 '21 at 19:19
Huh, how did you shut off the gas before breaking it then?
Something is accessible so you should start with that something and run a new line. The existing line doesn't have enough accessible length for you to add a joint properly.
Based on your edit you need to disconnect this union and run new pipe. This of course assumes that the right side leads up to your fireplace.
MonkeyZeus
  • 16,461
  • 59
  • OP mentions a valve "there is a gas valve key/escutcheon beyond this point", see comment under my answer. I think OP should sketch the situation better, for everyone here trying to help. – P2000 Dec 16 '21 at 19:15
  • @P2000 Regardless, assuming OP is not currently high in natural gas and mercaptan then the only correct course of action is to get stuff replaced back to a healthy situation. – MonkeyZeus Dec 16 '21 at 19:23
  • Added some more info in the post. Behind the fireplace is both a valve key as well as a valve on the rigid pipe in the basement leading to the fireplace. Both were closed. – Thermidor Dec 16 '21 at 20:48
    @Thermidor Thanks, see my edit. – MonkeyZeus Dec 16 '21 at 21:02
CSST terminations typically require that you wrench on the last inch or two of tubing, much like a compression fitting for plumbing. You'd need to gain a little slack there to accomplish a safe connection.
https://www.youtube.com/watch?v=oHqgFm9Li2s
I'm not a Chicken Little and won't try to scare you away from working with gas lines. (By the same rationale none of us should be operating or fueling motor vehicles.) Just be sure you do it safely and properly in accordance with local laws. Test thoroughly, both with pressure and liquid leak detection.
    " I ... won't try to scare you away from working with gas lines" - I disagree. Gas is dangerous, [and is even on the "Never DIY this" list](https://diy.stackexchange.com/a/2753/142784). This should be done by a professional – cocomac Dec 16 '21 at 05:05
    When it all goes wrong, your insurance company will give no support as you didn't used an experienced, competent fitter. As often is the case, location would mean answers could be more apposite. – Tim Dec 16 '21 at 11:43
    Dv on the grounds that there's not an inch or two to get a compression joint on, and local byelaws will most likely outlaw any amateur messing anyway. – Tim Dec 16 '21 at 11:59
  • To be fair, _I_ put a new flexible gas line on when I replaced my gas water heater 15+ years ago. Probably not my best move, but I had plenty of room to work on tightening it against the existing rigid pipe and onto the heater's fitting _and_ I did test it thoroughly with soapy water. We're all still here, so it is possible for an amateur to get it right. Of course, the internet wasn't here to remind me of all the dangers back then... – FreeMan Dec 16 '21 at 12:46
    +1 from me. A fitting or flex hose hookup doesn't require a professional if you do your due diligence. Most flex hose kits come with leak test solution anyway, and as long as you leave some time between turning on the gas and starting up your appliance, you'll smell a leak before it becomes a problem. That said, if it requires running lines through the wall, that's when I would call in a pro. – Dan A. Dec 16 '21 at 15:10
    @DanA. why "if it requires running lines through the wall, that's when I would call in a pro" ? Running flex hose through walls, joists etc is easy if you stick to required clearances and bending radius. – P2000 Dec 16 '21 at 18:48
    This answer is specific to HomeFlex CSST and many modern supply lines. Ignoring the fact that OP would need to make a new clean cut I would hazard a guess and say that OP is looking at an old style appliance connector and is unlikely to find a proper fitting. They should trace the line back to wherever it originates and do it right. – MonkeyZeus Dec 16 '21 at 19:15
    The only trouble is that OP says he broke an _appliance connector_. Though the materials are similar to HomeFlex and other CSST building plumbing products, it would be inappropriate to use a CSST fitting to repair an appliance connector even if the physical sizing makes it appear the fitting should be compatible. – Greg Hill Dec 16 '21 at 23:34
    Yeah, -1 for encouraging DIY on gas. I don't really care if my neighbours choose to take a risk and end up electrocuting their whole family, but I sure as hell don't want their stupidity to cause their house to explode because that makes a bad day for *everyone*. – J... Dec 17 '21 at 14:19
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/132410/discussion-on-answer-by-isherwood-can-i-safely-connect-barely-reachable-flex-gas). – BMitch Dec 17 '21 at 14:51
