I am using 2-4 foot limestone boulders as rip rap in a nearby canal. I'm trying to avoid buying EXPENSIVE mining/lapidary equipment. It is very SLOW work however to cut off the sides of the boulders to prevent them from rolling down the embankment. I have been using 9 inch grinders with diamond blades. Turns out limestone is kinda hard. It is so porous, I thought it would be faster cutting. I have used feather and wedge, but with mixed results on this very holey limestone. Are there any better ways?
J...
  • 1,383
  • Can see this using just hand tools. https://www.youtube.com/watch?v=otiO_wKCwEc – crip659 Dec 22 '21 at 20:58
    Drill and split with the grain - multiple small chisels hammered in. – Solar Mike Dec 22 '21 at 21:09
  • Solar Mike, thank you for posting - Yes, I have used that route, it's just slow, with very holey rock, quite slow as I have to drill a lot of holes to get leverage. – Sean Atkinson Dec 22 '21 at 22:39
    @SeanAtkinson -- is this a situation that your local stormwater/water-resources authority is like, refusing to fix? – ThreePhaseEel Dec 23 '21 at 01:38
    I think it's worth stating that undertaking clandestine public works projects without permission on city or other property you do not own is opening the door to a potential legal nightmare. – J... Dec 23 '21 at 09:11
  • threephaseeel Yeah, they’d rather wait till there is a complete disaster, and we cant get into our homes, then spend hundreds of thousands, over two years. We have an insane clown posse for municipal and state government ( Governor was a close Trump supporter). – Sean Atkinson Dec 24 '21 at 05:06
    @SeanAtkinson I suspect the Insane Clown Posse would actually not appreciate the comparison – le3th4x0rbot Dec 24 '21 at 16:03
  • You can usually rent/lease heavy equipment rather than buying it. – RBarryYoung Dec 24 '21 at 19:22
Drill and split with feathers and wedges. I can't imagine using a grinder to do this work.
SDS max rotary hammer and 4 cutting edge carbide bits.
Fresh Codemonger
  • 13,439
  • J.. I gotta protect my property, it’s not like they are. Also , clandestine? “ kept secret or done secretively, especially because illicit” Sounds a bit much. Simply protecting an embankment. Neither in secret not illicitly. – Sean Atkinson Dec 24 '21 at 05:21
Option 1
Use concrete to stop the rocks from rolling, you can get white cement (for a small extra cost over the price of grey cement) and if you use it with white aggregate (e.g. quartz or marble chips) it will be basically the same colour as limestone,.
Option 2
Get a larger drill or electric jackhammer. if you don't like the price hire one for a few hours and see if it does the trick.
Option 3
A grinder is the wrong tool, you really need a wet saw to cut rock, the water will reduce the amount of airborne dust, and save quite a lot of wear on the expensive blade.
If you take some rock samples to the tool hire place they may be able to offer advice and may even let you try their tools out for free.
Jasen
  • 19,044
Find a source for smaller rock that will not have a tendency to roll. In a very similar situation I used defective bricks. There was a brick factory in the area and I found they sold defective brick very cheap, essentially fill. The full and half bricks were very stable in a very fast river bank, faster than your flow. In a heavy rain my stream rose over 12 feet, sort of a ravine with flat shorelines. So a half brick size gives a general idea what size you need. My soil was sand so very susceptible to erosion. I did add many cuttings of water tolerant brush like redtwig dogwood, but the brick was essential .
blacksmith37
  • 8,271
    blacksmith37- Thank you for your insight. The thing is, I can't use anything but 100% "native" plants or fill, so no one gets the idea we are trying to just get rid off garbage., plus neighbors would complain if I use anything but. Yes, I am def using plants as well. Other sources of rock, meaning selected rock, gets a lot more expensive. – Sean Atkinson Dec 22 '21 at 22:30
    I did not necessarily mean brick , but something like a large size crushed limestone. Redtwig dogwood is generic in US and Canada except the southern states and was the best of several plants I tried. – blacksmith37 Dec 23 '21 at 15:38
  • Gotcha, but currents displace smaller boulders. Also keeping to the same size that the city used in one area they did manage to reinforce. – Sean Atkinson Dec 24 '21 at 05:21
Do you get cold winters?
A traditional mining technique in the UK was to expose the limestone bed, cut vertical holes and grooves in selected places (with hand tools!), fill them with water, and wait for a winter or two to do the rest. The water froze, expanded, and cracked the rock. With a quarryman's skill, it cracked into rough cuboids that could be built into walls without further shaping being necessary.
Anyway, experimentally, you could try drilling a few vertical holes into some boulders, filling them with water, and wait to see what winter does to them. Experiment with hole diameter and depth and spacing.
Obviously if you do not get cold winters, this idea won't fly.
The other answer which probably isn't what you want, is to use gabions. These are enclosures made of tough approximately 2 inch square mesh) , something like two feet cubed. You fill them with crushed rock. By the time the wire mesh rusts, weathering, dust, and vegetation has bound the crushed rock together. It's a common technique (in the UK at least) for reinforcing unstable river banks or embankments.
nigel222
  • 778
    map above indicates the OP is at the southern end of Florida, so freeze/thaw cycles aren't going to be available. – user4556274 Dec 23 '21 at 12:24
  • Expanding mortar (eg expando) could do the job instead, but probably no better than the already rejected "feather and wedge" – Jasen Dec 23 '21 at 13:49
  • One cut per year or two seems like an impossibly slow way to go about this... feathers and plugs have been around for thousands of years for a reason. – J... Dec 23 '21 at 17:18
  • @J... It was a method used for mining Cotswold stone and similar before power machinery or diamond saws. Very economical of human effort (but needed skill to get the cracks in the desired places). You prepared as much stone as you needed, then just waited until spring. (The UK is now too mild to use this method - many years, no snow, no really hard frosts). – nigel222 Dec 23 '21 at 17:35
  • @nigel222 Sure, the economy/lazy factor is obvious - as long as you're not in a hurry for your blocks, I suppose, yeah, no doubt it would work. – J... Dec 23 '21 at 18:13
