I want to create a permeable (allowing things to pass through) sound barrier (noise barrier, soundwall, noise wall) for soundproofing purposes. It is for a room and specifically for the doorway/entrance (without a door).
Type: Standard Doorway
Height: 80”
Width: 36”
Criteria:
- The sound barrier should be permeable. I can walk through the sound barrier.
- The solution should not make noise itself. (maybe it can be faint like a desk fan on low speed so it doesn't disturb)
- It should block noises/sound coming from outside the room to a certain degree (music, people talking/walking/doing mundane activities, distant sounds coming from outside the building)
I'm not very knowledgeable in acoustics but I believe the barrier should block sound between bass and higher midrange in audio frequency spectrum. (You can correct me if you know better or based on what is possible)
Bass: 60 – 250Hz
Lower midrange: 250 – 500 Hz
Midrange: 500 – 2kHz
Higher midrange: 2 – 4kHz
Any ideas/technological solutions on how to create this permeable soundproofing barrier/system?
Note: Just to be more clear, it is a hole. It is a doorway without a door, an entrance, an opening. It is a permeable sound barrier (soundproofing) for a hole/opening basically. I thought there could be solutions with active noise cancelling or through certain sound waves/mechanical waves/electromagnetic radiation etc. Also, soundproofing the hole/doorway might be part of a bigger system.
