At home, the power cables in my hallway are running parallel (for about 4-5 metres) to the Cat6 UTP ethernet cables, with a gap of about 100mm. One of the ethernet cables will be PoE and the others are non-PoE.
Where one of the non-PoE ethernet cables branches off into the adjoining rooms, they do so at a perpendicular angle over the power cables. The PoE cable will continue to run without crossing over the power cable.
I haven't yet moved into the house, so haven't tested the signal or observed any issues yet.
Q: Is the 100mm gap sufficient? Or is this going to present any issues?
MAK AK
  • In my house I have ethernet cables running parallel to mains cables and cable-tied together. There is no problem. I assume you are using screened cables. – Chenmunka Jan 26 '22 at 11:13
  • @Chenmunka What do you mean by "screened cable"? Here is a link describing my Cat6 UTP cable: https://www.securiflex.co.uk/cat6-u-utp-colours – MAK AK Jan 26 '22 at 11:18
  • Cat-6 is normally screened to protect against interference. Most, but not all, data cables are. – Chenmunka Jan 26 '22 at 11:22
  • @Chenmunka Do you mean shielded when you say "screened"? If so, no, this is UTP (unshielded twisted pair). – MAK AK Jan 26 '22 at 11:23
    It'll be fine. No gap is actually required. – brhans Jan 26 '22 at 11:35
  • https://diy.stackexchange.com/a/194565/18078 – Ecnerwal Jan 26 '22 at 12:11
    Ethernet runs at 100-500MHz. Compared to those frequencies, line AC is virtually the same as DC. You don't need to worry about it. – whatsisname Jan 26 '22 at 16:45
0 Answers0
