During my latest foray into the attic, I discovered that my bathroom exhaust fans vent directly into the attic. I'm worried about moisture buildup and I'm considering routing the exhaust to an external vent. How major of an issue is this, and which type of vent is best?
From my perspective, a soffit vent is going to be easier to do and doesn't have the potential to allow rain to leak into my attic. Is there any strong argument for a roof vent?
I found this article explaining a basic how-to of each procedure, but it doesn't give any pros/cons for each one.
Doresoom
  • 15,623
  • 80
  • 118
  • There is a flap on most vent housing units that prevents air from back flowing in from a soffit. –  Jan 20 '13 at 18:43
Soffit
Pros
  • Vent easier to install
  • In heavy snow areas, not likely to be blocked
Cons
  • Soffits are designed for intake, so it's possible the air will be sucked back into the attic
  • Moist air can collect under the soffit
Roof
Pros
  • Heat and moisture want to rise
  • Keeps moisture away from walls, windows, siding
Cons
  • Can be blocked with heavy snow
  • More difficult install
I don't think it's that difficult to install a roof vent - this is a pretty good video
Steve Jackson
  • 3,780
  • 37
  • +1: I hadn't considered that soffit is for air intake, so the moist air might end up in the attic anyway. Also, great video resource! – Doresoom Oct 26 '10 at 17:14
  • Won't the exhaust heat melt the snow buildup? – Joe Phillips Oct 26 '10 at 17:33
  • Snow buildup isn't really a concern for me - I live in Alabama. – Doresoom Oct 26 '10 at 17:42
  • @Joe I wouldn't worry about the snow thing in most cases, but my brother tells me some states require an install above the roof snow line. May or may not affect the placement and make a soffit vent an alternative. Also can't really speak for places that live under feet of snow, I know they've got exchangers for stoves and whatnot, not sure how bathroom exhausts are handled. – Steve Jackson Oct 26 '10 at 18:09
    Little late to the party here, but if you put a p-trap in the line, it won't allow heat to escape through the roof vent... (unless, of course, the bathroom fan is on.) – Michael Jul 26 '11 at 07:50
The natural flow of air in an attic is going to be pulling air in through the soffit vents and out through the roof vents/ridge vent.
The problem I see with exausting the air through a soffit vent is that the natural flow is going to tend to pull that moist air right back in through the soffit vents and into the attic again.
Given that the air flow through an attic is mostly based on convection and probably pretty slow, this may not be an issue in reality, but it would certainly make me think twice about doing it.
Eric Petroelje
  • 9,661
  • 40
  • 62
  • +1: Great answer! Steve just *barely* beat you to the answer, so I'm accepting his. – Doresoom Oct 26 '10 at 17:15
  • I always question how much moist air could be sucked back into the attic through a soffit vent. As you mention, the velocity of air *into* the soffit will be low. That with the fact that the vent fan is actively blowing the moist air *away* from the soffit would seem to combine to let very little moist air back into the attic. – hazzey Apr 21 '16 at 18:28
