I’m installing a 60a sub panel in the garage to feed a car charger and serve as the tie point for a portable generator. The garage is on the other end of the house so I only want to pay for 1 cable run, hence the subpanel. what residential interlocks are available to interlock the gen breaker in the garage sub panel to the main breaker in my main panel? All the interlock kits I see are for breakers in the same panel. Thanks in advance
Asked
Active
Viewed 54 times
3Well, we can help *A LOT* with the cost of wire. Are you willing to let go of some wrong superstitions? – Harper - Reinstate Monica Feb 07 '22 at 22:11
Have you already put the conduit in the ground? – whatsisname Feb 08 '22 at 01:13
Is the garage attached or detached? – ThreePhaseEel Feb 08 '22 at 02:32
"alternative" being a word for "not code compliant, no way, no how" here. Well, you can be code complaint if you only want the garage circuits to run from the generator. See https://diy.stackexchange.com/a/37031/18078 – Ecnerwal Feb 08 '22 at 13:12
I added an answer to the other question. Upshot: lose any superstitions about aluminum wire... and *voila*, costs fall right into line. – Harper - Reinstate Monica Feb 08 '22 at 21:10
