I have a main drain line running from my 1940s era single family residence in Las Vegas, NV to the city sewer. Given the time period I had assumed it would be cast iron, but when I dug down to it, it didn't quite look like cast iron I'd seen before. It has a distinct hammered, shiny finish and has zero corrosion, despite being buried in the ground for (I assume) nearly 80 years. Can anyone verify that cast iron looks like this sometimes? If not, what else could it be?
Thanks in advance!
JG307
It will be hard to definitely identify the material. Given the time frame, my first guess would have to be Orangeburg pipe. The shiny surface could be from the coal tar used to cover the pipe. The only problem is that it looks in amazingly good shape, might be due to the dry Las Vegas climate. A picture of it is shown below. (from web, Paul Duffau)
JACK
  • 78,739
  • 72
  • 188
  • If the magnet does **not** stick, this is highly likely. – Ecnerwal Feb 26 '22 at 23:56
    @Ecnerwal The magnet did not stick. I am not happy. lol – JG307 Feb 27 '22 at 00:14
  • Looks ready for 80 more years - best looking piece of installed Orangeburg I've ever seen. Most look worse than the picture in this answer - often far worse. In most places the first 10 feet from the house will be cast iron, if that helps any. – Ecnerwal Feb 27 '22 at 00:26
  • @ecnerwal Thanks haha. It feels incredibly hard and sturdy. When I was under the impression it was cast iron, I was standing on it as I dug out the hole around it, even after taking out the dirt supporting a 2ft span of it, it supported my weight no problem. – JG307 Feb 27 '22 at 00:35
    Hmm. I've never seen tar-coated asbestos-cement pipe, but I have to wonder if that's a possibility. Ususally that stuff is gray-white and may even have "Transite®" proudly molded into it every few feet. – Ecnerwal Feb 27 '22 at 00:48
  • @Ecnerwal Yes, they were very proud of their name Transite". We had a ton of it buried many years ago for UG powerline spare conduits. By the time we needed to use it, it had all collapsed and was useless. Never saw any tar coated though. – JACK Feb 27 '22 at 01:11
