12
When you press the test button on a smoke detector it obviously beeps, but I'm assuming it doesn't just test the speaker. So, how does the test work? I can't see a practical way to release smoke within the alarm itself, so does it use some other measure in order to break the flow of radiation?
DarkLightA
  • 443
Ionization smoke detectors use a radioisotope to generate a very small electrical current, which when interrupted causes an alarm to sound. These types of alarms use a metal–oxide–semiconductor field-effect transistor (MOSFET) to prevent the alarm from sounding, as long as the tiny current is flowing from the detector.
A simple dumbed down version of the circuit, might look something like this.
Simple Smoke Alarm Circuit
Notice the 9V battery is connected to the Source contact of the MOSFET, the detector is connected to the Gate, and the Alarm is connected to the Drain. This means that as long as there is a current on the gate, current will not flow from the source to the drain. If something (smoke) interrupts the current flow to the gate, current will flow from the source to the drain and the alarm will sound.
If you add a normally closed switch to the circuit, like so.
Simple Smoke Alarm Circuit with Test Button
Opening the switch will prevent current from flowing to the gate, simulating a loss of current flow from the detector. Which in turn, will cause the alarm to trigger.
Simple Smoke Alarm Circuit with Test Button Open
So when you press the test button on an ionization type smoke detector, you're not actually testing the circuits ability to detect smoke. Rather, you're testing the circuits ability to react to a loss of current flow to the gate contact of the MOSFET. You're also making sure the battery is not dead, and has enough juice left to sound the alarm if need be.
